Hello All,
I am quite new to photoshop, so thank you in advance for your patience.
When I use the eraser, I get a black line outlining the path that the eraser took.
Here, I drew a square, then erased a path through the top and left side. I now have two discrete, closed sections. I intended to get a clean erasure resulting in a two-line shape in the upper left, and a four sided, open shape in the rest of the image. Basically, I want it so they are not closed shapes.
And advice? Thanks.
Welcome to the forum.
I think you are doing something different than you think you are.
To check open a new document (file/new). Draw a black square with the paint brush then erase a section as above. Think you will just see erased section.
Do you have eraser in brush mode (box in eraser tool bar)?
Do you really have a white canvas with a black line?
You can use the rectangular marquee tool to draw a square and then go to Edit>Stroke, but you loose the ability of easily changing your edits.
You could also save a layer style and use that with shape layers (or any layer), but you would still have to add a layer mask unless you recorded an action.
