I just reconverted a large wedding to dng files, not remembering that I had done that last week. So now all the files are named Jamie & Ben-001-2, Jamie & Ben-002-2....& so on...I would like to rename them back to get rid of the -2 numbers. Can not find a way to do it in LR. I can do it in Bridge, but this gives me the little "?" in the corner, so I have to point LR to the file. And it does not want to find all of the nearby files, even though the "find nearby missing photos" button is checked. There was a ton of work done to these images, so I do not want to loose all of the Development History. I can just leave the numbers as they are if I have to. I just would like to correct my dumb mistake.
This is kind of unclear.
Saying "I can do it in Bridge" is not the same as "I changed the file names in Bridge".
Did you or did you not make this change in Bridge?
If you didn't, then I would say just leave the number as they are. Forget this entire idea of renaming them, it will only cause you trouble.
If you changed the file names in Bridge, you have what we call a "mess" in technical terms, and I think you are going to have to re-link them one by one in Lightroom, or find an automated way to change the file names back so they have -2 on the end.
No, the file names changed to the -2 numbers when I by mistake reconverted all of the images to dng a second time. This created new files, and replaced the old ones. I can correct the numbers using Bridge. But then I need to redirect LR to find the renamed file. And that seems to be a one at a time thing. Seeing as there are almost 700 files, this ain't gonna happen. Yes, it is a mess. So I will probably just leave them as is unless someone has an easy fix.
Yes, I can get it to rename Jamie & Ben-001-2 to Jamie & Ben. Then I could add a sequence number. That would work except that there are 666 images, numbered from 001 to 672. So a few have been deleted after the original naming. I have to keep the 3 digit number as they are, since the customer already has proof slideshows.
Try it not with your copies. If they are copies then the "-2" is expected and Lr might consider this as the "original name" since this is the name that the copy was given when it was created.
Try it with the originally mis-named files; not with copies of the mis-named files.
It works perfectly here. I re-named a few files, then re-named back to <Original filename> with the procedure described. Works like a charm.
Geoff & w-w. I figured out how to do it! I noticed on the File Template Editor, there is a "Title" option. So, I used a plug-in I have called Search Replace Transfer. Here is a link to it.
http://www.photographers-toolbox.com/products/jbeardsworth/findreplace /index.phphttp://
So, this is what I did.....
For some reason, if I just entered -2 step 3, when I went to F2, the file name would show up as Jamie & Ben Wed-017.dng.dng. That is why I included the .dng in step 3.
That's a great, creative way of solving your problem (and a nice piece of documentation
). Thanks for posting your solution.
I suspect if you would have used "Copy the filename to the title field without extension" in step 2, this would not have been necessary.
Beat
Message was edited by: b_gossweiler
