For some reason I was not able to post this in the Livecycle ES forum, even though I've posted there often in the past.
I have created a form that I almost have working and I'm hoping someone can help me.
We have eight billing teams in our company and each team works anywhere from 1 - 4 different clients. The form is used to track, per Billing Rep, the number of items of mail that each billing r5ep works each day. What I'm needing to add at the bottom is a subform that tracks the totals by client. So I'm trying to get the form to loop through all of the existing subforms (and the subforms within them) and compare a cell int he bottom subform to a cell in the other subforms, which are dynamically added, and then total ONLY those items. My script however is not working.
What I have now is:
var repCount = form1.P1._rep.count
var itemCount = form1.P1.rep._ItemSet.count
for (x=0; x<repCount; x++)
for (i=0; i<itemCount; i++)
if(clientName.rawValue == P1.rep[x].ItemSet[i].client.rawValue)
this.rawValue = this.rawValue + P1.rep[x].ItemSet[i].corresp.rawValue;
It seems like this should work but I'm getting the following error:
P1.rep[x] is undefined
So what it looks like is I'm missing is the proper way to reference the objects in these subforms.
The form is here: https://acrobat.com/#d=20gWXZ4sBm4OPV6oO76zSg
If someone could take a look at it I would be so grateful.
Jo
Sorry I cant see your document link - probably have to publish it first. However from looking at the script you are using array notation in javascript to access object collections. The hierarchy object model is not a javascript array but rather a collection of dom objects even though the som expressions use them as accessors in formcalc for example.
would be invalid javascript since rep is not an array. Probably would need to be P1.resolveNode("rep[x].ItemSet[i]").client.rawValue
Thanks for your help. I published it here:
Can you try again.
Also, I have updated the script as you suggested to this:
for (var x=0; x < repCount; x++)
for (var i=0; i < itemCount; i++)
if (P1.resolveNode("rep["+x+"].ItemSet["+i+"]").client.rawValue == clientName.rawValue);
this.rawValue = this.rawValue + form1.P1.resolveNode("rep["+x+"].ItemSet["+i+"]").corresp.rawValue;
Now, when I run it, it gives me totals, but it puts the same totals into both fields.
Your if statement has a ; at the end basically making the test redundant and executing the code block following at all times. You also should not do - this.rawValue = this.rawValue + ... since it will keep adding on every calculate. Start from 0 in a local variable and assign it to the rawValue at the end.
Thank you so much! I have it working now...EXCEPT...when I add some numbers to that first column, and then add another rep using the "Add Billing Rep" button, I get an error that says:
"P1.resolveNode("rep[" + x + "].ItemSet[" + i + "]") is null".
If I add some additional reps before I enter any numbers, it only includes the most recently added numbers.
The updated form is here: https://acrobat.com/#d=nLDPPNd7fKXPYsnH2Z*oyA
Any idea what I'm missing?
Thank you muchly.
Jo
Have a look at this version. https://acrobat.com/#d=xScv0bjZI7SjvjsyG7ZUrQ.
I have used a variable to keep track of the subtotal and then apply that after the loops.
Also I would not use x as a variable name, as it is a reserved word.
Hope that helps,
Niall
Thank you for following up with me on this Niall...I really like how automated that is. However, I'm getting an error. If I add values to the first column for the first billing rep, then add another billing rep, I get the following error:
P1.resolveNode("rep[" + j + "].ItemSet[" + i + "]") is null
7:XFA:form1[0]:clientTotals[0]:correspTotal[0]:calculate
TypeError: P1.resolveNode("rep[" + j + "].ItemSet[" + i + "]") is null
7:XFA:form1[0]:clientTotals[1]:correspTotal[0]:calculate
7:XFA:form1[0]:clientTotals[2]:correspTotal[0]:calculate
What does this mean?
Also, the totals for the billing reps added after the first one are not added to the totals at the bottom...sometimes. It's really strange behavior. Sometimes it will add the totals at the bottom and sometimes it throws an error.
Joanne
Here is what I have working so far. I'm getting a big error when I open the file. And some totals for some reason just aren't making it to the grand totals section at the bottom.
In this file....https://acrobat.com/#d=cP07gIScGXyacqca6Rcmyg
I get these results. It looks like it totals at the bottom for additional billing reps sometimes, but not all the time:
And, in the file which you worked for me Niall, it's throwing the errors I noted above, and also not totalling for any additional billing reps:
I am so at a loss as to how to work this out. I would be extremely grateful if anyone could help me figure out how these glitches are occuring. Any ideas?
Jo
I don't know that anyone else will ever have a similar problem as what I was having, but I figured I would go ahead and post the solution, just in case....
The error I was getting (P1.resolveNode("rep[" + j + "].ItemSet[" + i + "]") is null) was occuring because the variable itemCount needed to be referenced within the repCount For Loop. I also needed to resolve the node for the itemCount, which I wasn't doing.
So...my old code was this:
var repCount = P1._rep.count;
var itemCount = P1.rep._ItemSet.count; //this part was throwing the error. Needed to use resolveNode...and needed to not declare the variable until inside the first For Loop.
var nTotal = 0;
for (var j=0; j<repCount; j++) {
for (var i=0; i<itemCount; i++) {
if (P1.resolveNode("rep["+ j +"].ItemSet["+ i +"]").client.rawValue == clientName.rawValue) {
nTotal = nTotal + P1.resolveNode("rep["+ j +"].ItemSet["+ i +"]").corresp.rawValue;
this.rawValue = nTotal;
...which wasn't working because it was trying to reference the count of the ItemSet right up front...but it needed to wait until it got inside the first iteration of the repCount subfields...AND it needed to have resolveNode used.
The corrected code is:
this.rawValue = 0;
var itemCount = P1.resolveNode("rep["+j+"]")._ItemSet.count; //corrected code...node is resolved and variable is declared within the first subform repCount.
this.rawValue = this.rawValue + P1.resolveNode("rep["+ j +"].ItemSet["+ i +"]").corresp.rawValue;
...which now works perfectly...and I'm throwing a party to celebrate! LOL
Jo
