Moving CSS Image Sprites On A Site
Apr 11, 2012 10:05 PM
I am using a rollover pure css image sprite on a site.
I was wondering how you would move them around, so you can wrap text around them? Basically treat the sprite like an image.
Here is the CSS for the sprite I am using for the sprite:
a.image_sprite:link, a.image_sprite:visited {
    display:block;
    width:310px;
    height:259px;
    text-indent:-9999px;
    background-image: url(assets/image_one.jpg);
    background-repeat: no-repeat;
    background-position: 0 0;
a.image_sprite:hover, a.image_sprite:active {
    display:block;
    width:310px;
    height:259px;
    background-position: 0 -259px;
    font-family: Arial, Helvetica, sans-serif;
Here is the sprite inside the html with text that i want to wrap around it:
<div class="content"><p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nulla suscipit varius sem, ac tincidunt dolor egestas sed. Vestibulum ante ipsum primis in faucibus orci luctus et ultrices posuere cubilia Cura</p><p><a href="#" class="image_sprite"></a></p>
  <p>Lorem ipsum <br/>
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nulla suscipit varius sem, ac tincidunt dolor egestas sed. Vestibulum ante ipsum primis in faucibus orci luctus et ultrices posuere cubilia Cura</p></div>
    Apr 11, 2012 10:07 PM   in reply to Seaside333
    Do you have a link or a screenshot so we can see what you are trying to do?
    Apr 11, 2012 10:11 PM   in reply to Seaside333
    If I understand correctly you can either add an align rule to your css or select your image and set the alignment in the property inspector.
    Apr 11, 2012 10:12 PM   in reply to Seaside333
    You may also need to remove the <p> tags from your image.
