trying to install Acrobat X Standard from disc. Computer gives me message that I have not met the system requirements. But I have, so what do I do?
What are your system info....
check here http://www.adobe.com/products/acrobatstandard/tech-specs.html and compare
First check form the below link that you actually meet the system requirements.
http://www.adobe.com/products/acrobatpro/tech-specs.html
If you do, then copy the contents of the disc to a folder on the desktop and try running the installer and check if it works.
What's your screen resolution? A lot of such failures hinge on this trivial thing, meaning that the installer may not read the resolution correctly, even though it is actuall quite large. Can happen on notebooks with external graphics output or desktop machines with multiple displays that are conencted in an odd order... Check your graphics driver and update it, if necessary.
Mylenium
