export anamorphic JPEG
Apr 11, 2012 7:01 AM
Hello,
Another problem, i would like to know how to export anamorphic JPEG images?
When you export JPEG in AE, pixel aspect ratio  have automatically the value 1, i would like to export one HDV frame 1440*1080 with a pixel aspect ratio of 1.33, is that possible?
Even if i set an output module template, i can't success?
Thanks in advance,
Fred
    Apr 11, 2012 7:16 AM   in reply to lougris17
    I can't see any preset resize settings in the output module that would give you that, but you could create a new output module template with the correct resize and have the script apply that.
    If the problem is that this still doesn't tag the output with the correct aspect ratio, maybe you could have the script put the output comp in another comp with the correct pixel aspect and render it through that.
    Apr 12, 2012 8:02 AM   in reply to lougris17
    So it sounds like you do want the file to be tagged with the correct pixel aspect. I don't know about this myself, but I would say that if you can do it in AE manually, you can probably do it with a script. And if you can't do it manually, it's unlikely you can do it with a script. So if I was you I'd look into that first, maybe asking about it in a more general AE forum.
