unable to remove stage event listener from child swf
Apr 12, 2012 Apr 12, 2012
Hi all I have made index swf which is loading other child swf's into index these swf's are images.swf, portfolio.swf, about.swf etc.., I have made 2 public function in each swf which is construct or diconstruct.
when i unload any swf then i play disconstruct public function of every child swf.. I stuck in when I remove stage event listener of every child swf then it shows error..
TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at library_fla::MainTimeline/diconstruct()
here my diconstruct function of all child swf
function diconstruct(){
          pic.video.gotoAndStop(1)
          stage.removeEventListener(Event.RESIZE, sizeListener);
how i delete stage event listener of every child swf..???? I feel it is showing error because it is trying to remove event listener from index.swf
ActionScript
910
Advocate ,
add trace statements to confirm which object is null.
also do you remove these swfs from the displaylist before you deconstruct them?
if so I think the stage property gets set to null (since they are not on the stage anymore)
and so stage.removeEventListener won't work
ya i am running deconstruct function before remove those swf. when i trace stage in child swf's then it  showing null.
Advocate ,
if it's stage that's null then the object can't be in the DisplayList
an alternative that by passes your problem but does not solve it
when adding your stage.removeEventListener(Event.RESIZE, sizeListener);
you could use
stage.removeEventListener(Event.RESIZE, sizeListener, false, 0, true);
this means the listener is eligible for garbage collection and you don't need to remove the listener
