hello
i test differnt settings for a application p2p multicast live stream
firt i think there a two differnet settings for h264 stream
1, use variable bitrate
camera.setQuality(0,70) 0 bandwith so variable bitrate is used only works with rtmfp not with rtmp right ?
in this mode the quality slider what is the diffenrt when i use 0 or 100 ? same?
2,fix bitarte
camera.setQuality(8192,100) set the max bitrate and best quality
for p2pmulticast ithink mode 1 is the best varibale bitrate right? the only problem is sometimes on motions the bitrate
i stoo high so i set both bandwidgh and quality ?
next i can not see any different if i use h264 profile MAIN or BASELINE or any change of the Profile Level
is there any limitation on resolution or anything else
best regards
https://bugbase.adobe.com/index.cfm?event=bug&id=3047043
in this bug i read
In Flash Player 11.1, we have changed the bitrate control for H.264 from variable bitrate (VBR) to constant bitrate (CBR). You can try two things:
1 - Use higher bitrate
2 - Set the quality
Jozsef
so in RTMFP vbr is not used too?
