steve29106335
Divx Plus
Apr 12, 2012 3:52 AM
Can I make a movie using Divx Plus in Premiere Elements?
    Apr 12, 2012 4:47 AM   in reply to steve29106335
    Divx is not an editable format, and it certainly won't work in Premiere Elements.
    You may be able to convert it to a DV-AVI using a program like Super, per the FAQs to the right of this forum, however, and then you can edit it in this program.
    http://forums.adobe.com/thread/415317
    Apr 12, 2012 6:22 AM   in reply to steve29106335
    It will make a Divx movie.
    You may need to use another processor to convert to Divx Plus.
    Apr 12, 2012 7:14 AM   in reply to steve29106335
    While I have not used the "Plus" version yet, I have Exported/Shared to DivX fairly often.
    In PrE, one would install the necessary CODEC's, and then under Export/Share, choose MS AVI. At Advanced, the Compressor can be chosen. The default is CinePak by Radius (a very old, and virtually useless CODEC), but from the drop-down, DivX Plus should be available.
    Unless there is some issue with the Plus version, it should Export/Share just fine.
    There is also a suite of DivX utilities, and one of those is their Pro Encoder. If one were to Exprt/Share in another format, that Encoder will do the compression. The old "Pro" suite was US $ 39, but I have not checked lately.
    Good luck,
    Hunt
