Drawing Straight Line angled path with no wavy distortion when scaled
Apr 12, 2012 5:04 AM
I'm a beginner using AI CS5.5, and trying to add  straight lines to a drawing, using the line tool. They are angled about 30 degrees from horizontal, parallel to each other. Used 2pt and color for lines. Everything looks great in AI. When I export the drawing to PNG for insertion as an illustration into InDesign and scale down (45%) the drawing to fit the InDesign page, the once perfectly smooth and straight lines are wavy, almost zigzaggy, slightly distorted. Not a good result.
Is there a better way to draw straight lines that are on an angle in the drawing so that they are perfectly smooth, and when scaled retain their smooth straight look?
Any help appreciated.
    Apr 12, 2012 5:16 AM   in reply to saratogacoach
    Save as a native illustrator file (.ai), and place that into InDesign. That way the vectors are maintained and the lines will stay smooth.
    Apr 12, 2012 5:46 AM   in reply to saratogacoach
    It's just the screen view that is jagged. You will find when it prints it will be correct. To see a more accurate version on your screen in InDesign, select your object and go to Object > Display Performance > High Quality Display
