i know its a bad practice to use timeline scripting but i was obliged to do that
if user clicked a button that will goto and play for example frame 10 and at frame 10 i have my game code that ill start
the problem is when user clicks the button ( i have a mosue event that shoots) so directly when its loaded i can see the shot in the middle of the screen how can i avoid this
is there something i can do to delay that
Timeline scripting is not a bad practice, thoug when using it there are numerous bad practices that should be avoided.
Your problem is not clear to me. If you are indicating that you have a moiuse event the results in something shooting, like a gun/bullet, then chances are you need to hold off assigning that event listener until it is time for it to exist. If you mean that you assign this listner in frame 1 but do not need it un til frame 10, then you could put a conditional inside its event handler that checks the frame before allowing anything to shoot.
no not like this
at frame 1 i got the button that when i click it goes at frame 10 for example at frame 10 we have the code of our game all the listeners etc...
the problem when i click the button everything works fine but when the game is loaded ( the bullets is there moving )
Date: Wed, 11 Apr 2012 07:32:04 -0600
[... contact info removed ...]
Subject: Re: Time line Time line
Re: Time line
created by Ned Murphy in Action Script 3 - View the full discussion
Timeline scripting is not a bad practice, thoug when using it there are numerous bad practices that should be avoided. Your problem is not clear to me. If you are indicating that you have a moiuse event the results in something shooting, like a gun/bullet, then chances are you need to hold off assigning that event listener until it is time for it to exist. If you mean that you assign this listner in frame 1 but do not need it un til frame 10, then you could put a conditional inside its event handler that checks the frame before allowing anything to shoot.
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Time line
To unsubscribe from this thread, please visit the message page at Re: Time line. In the Actions box on the right, click the Stop Email Notifications link.
Start a new discussion in Action Script 3 by email or at Adobe Forums
For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
If clicking the button isn't doing it, then it sounds like just entering the frame causes a bullet to be there. What makes the bullet appear? You need to make it such that it cannot happen.
You'll need to show relevant code if you want help... just explaining with words is not likely to work for you.
http://dl.dropbox.com/u/54627535/Untitled-1.swf
check this man , level 2 ( modern era) a
see when the game start the bullet
Seeing it doesn't help solve it. If you cannot answer the questions or provide what is asked for, there is nothing I can do to help you.
i only thought i didnt explain whats happening well anyway here is the code
here is the code
function startLevel2(event:MouseEvent):void
gotoAndStop("Modern Era " );
here we wo go load the game
from here we call the movebullet function
function frameListener(event:Event):void
if(!myTank.ismyTankDestroyed)
moveTank();
l2moveBullets();
if (! anEnemyTank.isDestroyed && !myTank.myTankisDestroyed)
moveEnemyTank(anEnemyTank);
moveGroundUnits();
moveEnemyBulletl2();
and here is the function of moving bullets
function l2moveBullets()
for (var i:int = 0; i < _l2bullets.length; i++)
bullet = _l2bullets;
//bullet.rotation = _turretAngle
bullet.x += bullet.vx;
bullet.y += bullet.vy;
//check the bullet's stage boundaries
if (bullet.y < 0 || bullet.x < 0 || bullet.x > stage.stageWidth || bullet.y > stage.stageHeight)
{etc .... }}
and we listen when the user click mouse to add the bullet to the array and prepare it for movement
function mouseDownHandler(event:MouseEvent):void | |||
fireBullet(); |
function fireBullet() | |||
var bullet:TankBullet = new TankBullet(getAnglel2()); | |||
stage.addChild(bullet); |
var radius:int = -20; |
var angle:Number = (myTank.rotation + myTank.turretMovieClip.rotation) * Math.PI / 180; |
//3. Position the bullet | |||
bullet.x = myTank.x +myTank.turretMovieClip.x + 20 + radius * Math.cos(angle); | |||
bullet.y = myTank.y +myTank.turretMovieClip.y - 5 + radius * Math.sin(angle); | |||
//Set the bullet's velocity based | |||
//on the angle | |||
bullet.vx = Math.cos(angle) * -7 + myTank.vx; | |||
bullet.vy = Math.sin(angle) * -7 + myTank.vy; |
//Push the bullet into the _l2bullets array | |||
_l2bullets.push(bullet); | |||
controlAudiol2(shootSoundl2); | |||
bombsLeftl2--; | |||
bombsLeftDisplay2.text = String(bombsLeftl2); |
trace("you still have " + bombsLeftl2); | ||||
if (bombsLeftl2 == 0) | ||||
stage.removeEventListener(MouseEvent.CLICK,mouseDownHandler); | ||||
//stage.addEventListener(MouseEvent.CLICK , playemptySound); |
It is nearly impossible to read the code you posted. While I can find that you have a MOUSE_DOWN event that triggers firing a bullet, I don't see where you added that listener, only where you remove it.
What I would guess is that you are entering the frame with the MOUSE_DOWN still registering from having clicked to get to the frame, which triggers the bullet to fire.
What kind of MouseEvent do you have triggering the startLevel2 function ? It should be a CLICK event
stop();
import flash.display.*;
import flash.events.*;
import flash.ui.Keyboard;
import flash.ui.Mouse;
import flash.geom.Point;
import flash.utils.Timer;
import flashx.textLayout.formats.BackgroundColor;
import flash.media.*;
import flash.media.SoundChannel;
import flash.media.SoundTransform;
import flash.text.*;
import flash.events.MouseEvent;
import level2.greensock.*;
import level2.greensock.easing.*;
import level2.shumi.l2Building;
import level2.shumi.enemy;
import level2.shumi.enemyTank;
import level2.shumi.ExplosionClass;
import level2.shumi.groundUnits;
import level2.shumi.Tank;
import level2.shumi.TankBullet;
var rightInnerBoundary:uint;
var leftInnerBoundary:uint;
var topInnerBoundary:uint;
var bottomInnerBoundary:uint;
var level2bg:aBackground ;
var aBuilding:l2Building;
var myTank:Tank ;
var ghostTank:Tank;
var hitCount:Number = 0;
var _l2bullets:Array ;
var _Gunit:Array ;
var groundUnit:groundUnits ;
var groundUnit2:groundUnits ;
var groundUnit3:groundUnits ;
var groundUnit4:groundUnits ;
var enemySoldier1;
var enemySoldier2;
var anEnemyTank:enemyTank ;
var speed:int = 1;
var radians:Number = 180 / Math.PI;
var turnRate:Number = .05;
var agroRange:Number = 300;
var distanceX:Number = 0;
var distanceY:Number = 0;
var distanceTotal:Number = 0;
var moveDistanceX:Number = 0;
var moveDistanceY:Number = 0;
var moveX:Number = 0;
var moveY:Number = 0;
var totalmove:Number = 0;
var hitCounter:Number = 5;
var bullet:TankBullet;
var shootSoundl2:shoot1;
var soundControl:SoundChannel;
var deadSound:dead;
var explodeSoundl2:explode;
var emptySound:empty;
var hitSound:hit;
var bombsLeftl2:Number ;
var textFormat:TextFormat = new TextFormat ;
var numberDisplay:TextField = new TextField ;
var Score:int ;
var scoreDisplay:TextField = new TextField ;//score display text field
var bombsLeftDisplay2:TextField = new TextField ;
var BombsNum:TextField = new TextField ;
var mybtn:btn = new btn ;
var mybtn2:btn2 = new btn2 ;
var myCursor:cursor = new cursor ;
var _l2Timer:Timer;
var enemyBullet1l2:TankBullet;
var _eBulletl2:Array;
var myTankHealth : uint = 10;
var gameOverScreen : MovieClip;
// var tankOffsetX :int = myTank.x + level2bg.x;
// var tankOffsetY : int = myTank.y + level2bg.y;
init();
function setuptextfieldsl2()
textFormat.font = "Helvetica";
textFormat.size = 25;
textFormat.color = 0x000000;
textFormat.align = TextFormatAlign.CENTER;
//Configure the score text field
numberDisplay.defaultTextFormat = textFormat;
numberDisplay.autoSize = TextFieldAutoSize.CENTER;
numberDisplay.border = false;
numberDisplay.text = "0";
scoreDisplay.defaultTextFormat = textFormat;
scoreDisplay.autoSize = TextFieldAutoSize.CENTER;
scoreDisplay.border = false;
scoreDisplay.text = "Score : ";
bombsLeftDisplay2.defaultTextFormat = textFormat;
bombsLeftDisplay2.autoSize = TextFieldAutoSize.CENTER;
bombsLeftDisplay2.border = false;
bombsLeftDisplay2.text = "50";
BombsNum.defaultTextFormat = textFormat;
BombsNum.autoSize = TextFieldAutoSize.CENTER;
BombsNum.border = false;
BombsNum.text = "Bombs Left :";
//Display and score text field
stage.addChild(numberDisplay);
stage.addChild(scoreDisplay);
stage.addChild(bombsLeftDisplay2);
stage.addChild(BombsNum);
numberDisplay.x = stage.stageWidth - 40;
numberDisplay.y = 10;
scoreDisplay.x = stage.stageWidth - 150;
scoreDisplay.y = 10;
bombsLeftDisplay2.x = stage.stageWidth - 55;
bombsLeftDisplay2.y = 40;
BombsNum.x = stage.stageWidth - 200;
BombsNum.y = 40;
function init()
Mouse.hide();
setuptextfieldsl2();
level2bg = new aBackground ;
aBuilding= new l2Building ;
myTank = new Tank ;
ghostTank = new Tank ;
_l2bullets = new Array ;
_Gunit = new Array ;
groundUnit = new groundUnits ;
groundUnit2 = new groundUnits ;
groundUnit3 = new groundUnits ;
groundUnit4 = new groundUnits ;
anEnemyTank = new enemyTank ;
bombsLeftl2= 50;
Score = 0;
myTankHealth = 10;
// set patroling points in an array, as many as u like, soldier will start at
// startPointX and StartPointY parameters passed in enemy creation
var patrolPointsSoldier1:Array = new Array ;
patrolPointsSoldier1.push(new Point(333,1440));
patrolPointsSoldier1.push(new Point(998,1447));
patrolPointsSoldier1.push(new Point( 600 , 1800));
var patrolPointsSoldier2:Array = new Array ;
patrolPointsSoldier2.push(new Point(444,1440));
patrolPointsSoldier2.push(new Point(1000,1460));
//enemy parameter (displayObjectContainer for stage refrence, PatrolPointArray,;
// startPointX, startPointY)
enemySoldier1 = new enemy(this,patrolPointsSoldier1,440,1440);
enemySoldier2 = new enemy(this,patrolPointsSoldier2,500,500);
rightInnerBoundary = stage.stage.width;
leftInnerBoundary = 0;
topInnerBoundary = 0;
bottomInnerBoundary = stage.stageHeight;
level2bg.x = 0;
level2bg.y = 0;
aBuilding.x = 700;
aBuilding.y = 750;
level2bg.addChild(aBuilding);
addChild(level2bg);
groundUnit.x = 500;
groundUnit.y = 290;
level2bg.addChild(groundUnit2);
level2bg.addChild(groundUnit);
level2bg.addChild(groundUnit3);
level2bg.addChild(groundUnit4);
level2bg.addChild(enemySoldier1);
level2bg.addChild(enemySoldier2);
groundUnit2.x = 780;
groundUnit2.y = 290;
groundUnit3.x = 500;
groundUnit3.y = 700;
groundUnit4.x = 70;
groundUnit4.y = 960;
_Gunit.push(groundUnit,groundUnit2,groundUnit3,groundUnit4);
myTank.x = 300;
myTank.y = 400;
this.addChild(myTank);
this.addChild(ghostTank);
ghostTank.alpha = 0;
anEnemyTank.x = level2bg.x + 500;
anEnemyTank.y = level2bg.y + 500;
level2bg.addChild(anEnemyTank);
shootSoundl2 = new shoot1 ;
deadSound = new dead ;
explodeSoundl2 = new explode ;
hitSound = new hit ;
mybtn.x = stage.stageWidth - 55;
mybtn.y = stage.stageHeight - 50;
mybtn2.x = stage.stageWidth - 90;
mybtn2.y = stage.stageHeight - 50;
myCursor.x = mouseX;
myCursor.y = mouseY;
addChild(myCursor);
addChild(mybtn);
addChild(mybtn2);
_l2Timer = new Timer(200);
_eBulletl2 = new Array ();
addListenersl2();
function controlAudiol2(snd:Sound):void
// if statement to avoid overlapping of sound objects
if (soundControl)
soundControl.stop();
soundControl = null;
var trans:SoundTransform = new SoundTransform(0.8);
soundControl = snd.play(0,0,trans);
//Remove the bullet from the stage
stage.removeChild(bullet);
//Remove the bullet from the _l2bullets
//array
_l2bullets.splice(i,1);
bullet = null;
//Reduce the loop counter
//by one to compensate
//for the removed bullet
i--;
if (bullet != null && bullet.hitTestObject(aBuilding.buildingMovieClip.buildinghitTest))
//Update the score, the score display
//and remove the bullet
aBuilding.destroyBuilding();
numberDisplay.text = String(Score);
controlAudiol2(explodeSoundl2);
bullet = null;
i--;
if (bullet != null && bullet.hitTestObject(anEnemyTank.enemyTankMovieClip.eTankHitTest))
anEnemyTank.destroyEnemyTank();
_l2Timer.stop();
_l2Timer.addEventListener(TimerEvent.TIMER, enemyTankShoot);
Score = Score + 50;
bullet = null;
for (var j:int = 0; j < _Gunit.length; j++)
if (bullet != null && bullet.hitTestObject(_Gunit
_Gunit
controlAudiol2(hitSound);
Score = Score + 50;
bullet = null;
function moveTank()
//THE TANK
//Increase the tank's speed if the up key is being pressed
if (myTank.accelerate)
myTank.speed += 0.1;
myTank.tankMovieClip.atank.play();
//Add some optional drag;
myTank.speed *= myTank.friction;
else
//Add friction to the speed if the tank is
//not accelerating
myTank.tankMovieClip.atank.stop();
//Calculate the acceleration based on the angle of rotation;
var tankAngle = myTank.rotation * Math.PI / 180;
myTank.acceleration_X = myTank.speed * Math.cos(tankAngle);
myTank.acceleration_Y = myTank.speed * Math.sin(tankAngle);
//Update the tank's velocity
myTank.vx = myTank.acceleration_X;
myTank.vy = myTank.acceleration_Y;
//Force the tanks's velocity to zero
//it falls below 0.1
if (Math.abs(myTank.vx) < 0.1 && Math.abs(myTank.vy) < 0.1)
myTank.vx = 0;
myTank.vy = 0;
if (myTank.x - myTank.width / 2 < leftInnerBoundary)
myTank.x = leftInnerBoundary + myTank.width / 2;
rightInnerBoundary = stage.stageWidth - myTank.x;
level2bg.x -= myTank.vx;
else if (myTank.x + myTank.width / 2 > rightInnerBoundary)
myTank.x = rightInnerBoundary - myTank.width / 2;
leftInnerBoundary = myTank.width / 2 + 10;
if (myTank.y - myTank.height / 2 < topInnerBoundary)
myTank.y = topInnerBoundary + myTank.height / 2;
bottomInnerBoundary = stage.stageHeight - myTank.y;
level2bg.y -= myTank.vy;
else if (myTank.y + myTank.height / 2 > bottomInnerBoundary)
myTank.y = bottomInnerBoundary - myTank.height / 2;
topInnerBoundary = myTank.height;
if (level2bg.x > 0)
level2bg.x = 0;
else if (level2bg.y > 0)
level2bg.y = 0;
else if (level2bg.x < stage.stageWidth - level2bg.width)
level2bg.x = stage.stageWidth - level2bg.width;
rightInnerBoundary = stage.stageWidth;
else if (level2bg.y < stage.stageHeight - level2bg.height)
level2bg.y = stage.stageHeight - level2bg.height;
//Move and rotate the tank
myTank.x += myTank.vx;
myTank.y += myTank.vy;
myTank.rotation += myTank.rotationSpeed;
if (myTank.hitTestObject(level2bg.hitTest1) || myTank.hitTestObject(level2bg.hitTest2) || myTank.hitTestObject(level2bg.hitTest3) || myTank.hitTestObject(level2bg.hitTest4) || myTank.hitTestObject(level2bg.hitTest5) || myTank.hitTestObject(level2bg.hitTest6) || myTank.hitTestObject(level2bg.hitTest7) || myTank.hitTestObject(level2bg.hitTest8) || myTank.hitTestObject(level2bg.hitTest9) || myTank.hitTestObject(level2bg.hitTest10) || myTank.hitTestObject(level2bg.hitTest11) ||myTank.hitTestObject(level2bg.gameHitTest1) || myTank.hitTestObject(level2bg.gameHitTest2) || myTank.hitTestObject(level2bg.gameHitTest3))
trace("tank hit" + myTank.x);
myTank.x = ghostTank.x;
myTank.y = ghostTank.y;
else
ghostTank.x = myTank.x;
ghostTank.y = myTank.y;
if (myTank.tankMovieClip.tankHitTest.hitTestObject(enemySoldier1._player.soldierHitTestPoint))
if (! enemySoldier1.isDead)
trace("hit soldier");
enemySoldier1.killSoldier();
controlAudiol2(deadSound);
Score = Score + 100;
//numberDisplay.text = String(Score);
if (myTank.tankMovieClip.tankHitTest.hitTestObject(enemySoldier2._player.soldierHitTestPoint))
if (! enemySoldier2.isDead)
enemySoldier2.killSoldier();
Score = Score + 200;
//THE TURRET
//THE TURRET
var _turretAngle:Number = getAnglel2();
_turretAngle -= myTank.rotation;
//Rotate the turret towards the mouse
myTank.turretMovieClip.rotation = _turretAngle;
//var angle:Number = Math.atan2 (mouseY - myTank.y, mouseX - myTank.x);
//myTank.turretMovieClip.rotation = (angle * 180 / Math.PI) - 180;
function getAnglel2():Number
//Convert turrets points from local to global coordinates
//Compensate for the rotation of the tank
var turretPoint:Point = new Point(myTank.turretMovieClip.x,myTank.turretMovieClip.y);
var turretPoint_X:Number = myTank.localToGlobal(turretPoint).x;
var turretPoint_Y:Number = myTank.localToGlobal(turretPoint).y;
var angle = Math.atan2(turretPoint_Y - stage.mouseY,turretPoint_X - stage.mouseX) * 180 / Math.PI;
return angle;
function addListenersl2()
stage.addEventListener(KeyboardEvent.KEY_DOWN,keyDownHandler);
stage.addEventListener(KeyboardEvent.KEY_UP,keyUpHandler);
stage.addEventListener(Event.ENTER_FRAME,frameListener);
stage.addEventListener(MouseEvent.CLICK,mouseDownHandler);
mybtn.addEventListener(MouseEvent.MOUSE_DOWN,onClickl2);
mybtn2.addEventListener(MouseEvent.MOUSE_DOWN,onClick2);
stage.addEventListener(Event.ENTER_FRAME,pauseListener);
function getAngle2l2(aObject2:MovieClip):Number
var turPoint:Point = new Point(aObject2.x,aObject2.y);
var turPoint_X:Number = aObject2.localToGlobal(turPoint).x;
var turPoint_Y:Number = aObject2.localToGlobal(turPoint).y;
var angle2 = Math.atan2(turPoint_Y - myTank.y,turPoint_X - myTank.x) * 180 / Math.PI;
return angle2;
function enemyTankShoot(event:TimerEvent):void
//Create a bullet and add it to the stage
enemyBullet1l2 = new TankBullet(getAngle2l2(anEnemyTank.enemyTurretMovieClip));
level2bg.addChild(enemyBullet1l2);
//Set the bullet's starting position
var radius:int = 30;
var angle:Number = (anEnemyTank.rotation + anEnemyTank.enemyTurretMovieClip.rotation - 15) * Math.PI / 180;
enemyBullet1l2.x = anEnemyTank.x + anEnemyTank.enemyTurretMovieClip.x + radius * Math.cos(angle);
enemyBullet1l2.y = anEnemyTank.y +anEnemyTank.enemyTurretMovieClip.y+ radius * Math.sin(angle);
//on the angle
enemyBullet1l2.vx = Math.cos(angle) * 5;
enemyBullet1l2.vy = Math.sin(angle) * 5;
_eBulletl2.push(enemyBullet1l2);
//Find a random start time for the next bullet
//var randomFireTime:Number = Math.round(Math.random() * 1000) + 200;
_l2Timer.delay = 750;
function onClick2(event:MouseEvent):void
function onClickl2(event:MouseEvent):void
stage.removeEventListener(Event.ENTER_FRAME,frameListener);
anEnemyTank.enemyTankMovieClip.eTreads.stop();
//Mouse.show();
fireBullet();
//on the angle
bombsLeftl2--;
explodeTank(myTank.x ,myTank.y,myTank);
myTank.ismyTankDestroyed = true;
endGamel2("You Loose");
function keyUpHandler(event:KeyboardEvent):void
switch (event.keyCode)
case Keyboard.LEFT :
myTank.rotationSpeed = 0;
break;
case Keyboard.RIGHT :
break;
case Keyboard.UP :
myTank.accelerate = false;
function pauseListener(event:Event):void
updateCursor();
moveTank();
l2moveBullets();
moveGroundUnits();
//checkWinner();
/* function rangeListener( )
var eDistanceX:Number = myTank.x - anEnemyTank.x;
var eDitanceY:Number = myTank.y - anEnemyTank.y;
var rangeDistance:Number = Math.sqrt(eDistanceX * eDistanceX + eDitanceY * eDitanceY);
if (rangeDistance <= 200)
_l2Timer.start();
else
_l2Timer.stop();
function moveEnemyBulletl2()
for (var i:int = 0; i < _eBulletl2.length; i++)
enemyBullet1l2 = _eBulletl2;
enemyBullet1l2.x += enemyBullet1l2.vx;
enemyBullet1l2.y += enemyBullet1l2.vy;
if (enemyBullet1l2.y < 0 || enemyBullet1l2.x < 0 || enemyBullet1l2.x > stage.stageWidth || enemyBullet1l2.y > stage.stageHeight)
level2bg.removeChild(enemyBullet1l2);
//array
_eBulletl2.splice(i,1);
enemyBullet1l2 = null;
if(enemyBullet1l2 != null && enemyBullet1l2.hitTestObject(myTank.tankMovieClip.tankHitTest))
myTankHealth --;
if(myTankHealth ==0)
endGamel2("You Loose ");
Mouse.show();
function endGamel2(Message:String)
Mouse.show();
gameOverScreen = new GameOVer();
gameOverScreen.gameover_txt.text = Message;
gameOverScreen.playAgain_btn.addEventListener(MouseEvent.CLICK, restartGame);
gameOverScreen.l2main_btn.addEventListener(MouseEvent.CLICK, l2MainMenu);
gameOverScreen.l2score_btn.addEventListener(MouseEvent.CLICK, l2Score);
addChild(gameOverScreen);
gameOverScreen.x = stage.stageWidth/2;
gameOverScreen.y = stage.stageHeight/2;
removeChild(level2bg);
stage.removeChild(numberDisplay);
stage.removeChild(scoreDisplay);
stage.removeChild(bombsLeftDisplay2);
BombsNum.text ="" ;
removeChild(mybtn);
removeChild(mybtn2);
bombsLeftDisplay2.text = "";
removeChild(myCursor);
function restartGame(event:MouseEvent):void
init();
removeChild(gameOverScreen);
myTankHealth = 10;
function l2MainMenu(event:MouseEvent):void
gotoAndPlay("GUI");
function l2Score(event:MouseEvent):void
gotoAndPlay("Score2");
function explodeTank(xPos:uint,yPos:uint,target:DisplayObject)
var anExp:ExplosionClass = new ExplosionClass(xPos,yPos,"bombExplosion");
addChild(anExp);
removeChild(target);
if (target == myTank)
stage.removeEventListener(KeyboardEvent.KEY_DOWN,keyDownHandler);
stage.removeEventListener(KeyboardEvent.KEY_UP,keyUpHandler);
mybtn.removeEventListener(MouseEvent.MOUSE_DOWN,onClickl2);
mybtn2.removeEventListener(MouseEvent.MOUSE_DOWN,onClick2);
stage.removeEventListener(Event.ENTER_FRAME,pauseListener);
_l2Timer.removeEventListener(TimerEvent.TIMER, enemyTankShoot);
//removeEventListener( Event:Timer,timerHandler);
function updateCursor()
function moveGroundUnits()
if(!_Gunit
_Gunit
function moveEnemyTank(object:MovieClip)
distanceX = myTank.x - object.x;
distanceY = myTank.y - object.y;
//get total distance as one number
distanceTotal = Math.sqrt(distanceX * distanceX + distanceY * distanceY);
//trace("dTotal"+ distanceTotal);
//check if target is within agro range
if (distanceTotal > agroRange )
//calculate how much to move
moveDistanceX = turnRate * distanceX / distanceTotal;
moveDistanceY = turnRate * distanceY / distanceTotal;
//increase current speed
moveX += moveDistanceX;
moveY += moveDistanceY;
//get total move distance
totalmove = Math.sqrt(moveX * moveX + moveY * moveY);
//apply easing
moveX = speed * moveX / totalmove;
moveY = speed * moveY / totalmove;
object.x += moveX;
object.y += moveY;
object.rotation = Math.atan2(moveY,moveX) * radians;
object.enemyTurretMovieClip.rotation = 0;
object.enemyTankMovieClip.eTreads.play();
_l2Timer.stop();
else
var eturretPoint:Point = new Point(object.enemyTurretMovieClip.x,object.enemyTurretMovieClip.y);
var eturretPoint_X:Number = object.localToGlobal(eturretPoint).x;
var eturretPoint_Y:Number = object.localToGlobal(eturretPoint).y;
var angle2 = Math.atan2(eturretPoint_Y - myTank.y,eturretPoint_X - myTank.x) * 180 / Math.PI;
object.enemyTurretMovieClip.rotation = angle2;
_l2Timer.start();
object.enemyTankMovieClip.eTreads.stop();
function keyDownHandler(event:KeyboardEvent):void
//trace("keyDownHandler");
myTank.rotationSpeed = -3;
break;
myTank.rotationSpeed = 3;
break;
case Keyboard.UP :
myTank.accelerate = true;
break;
case Keyboard.SPACE :
//fireMissiles();
here is the full code at the frame that got loaded from the button
the listener im using is an enter frame
hope it is clear now
if u check the game play u might under stand what i mean
Re: Time line
It is nearly impossible to read the code you posted. While I can find that you have a MOUSE_DOWN event that triggers firing a bullet, I don't see where you added that listener, only where you remove it. What I would guess is that you are entering the frame with the MOUSE_DOWN still registering from having clicked to get to the frame, which triggers the bullet to fire. What kind of MouseEvent do you have triggering the startLevel2 function ? It should be a CLICK event
I already told you I know what you mean. I will not even begin to try to find relevant code in all of what you posted.
so what i have to do now to fix the problem ?
Date: Fri, 13 Apr 2012 20:35:41 -0600
