pd.howie
Are you able to have different inset spacing measurements if a text box has rounded corners??
Apr 12, 2012 6:50 AM
Cheers
    Apr 12, 2012 7:27 AM   in reply to pd.howie
    Depends on the verion of ID, the insets realtive to the corners they need to describe a rectangle without rounded corners after the effect is applied, and whther you apply the insets or the corner effects first. This is not something I play with a lot, but I remember being able to fool ID into applying corners after the insets and leaving them at least once in the past.
    Apr 12, 2012 8:40 AM   in reply to pd.howie
    You just have to be sure that your corner effects don't impinge on the area inside the inset, I think.
    Apr 12, 2012 11:24 AM   in reply to Peter Spier
    hmmn: I cant seem to get it right...? I have used other work arounds in the past...
