winstart
export pdf with visibility control
Apr 12, 2012 8:16 AM
ik have a pdf with layers placed as an object in my CS5.5 document
now i want to export pdf's with control over the visability of the layers of that pdf-object
i can set the visability but, exporting gives 1 failure
how can i solve this
    Apr 12, 2012 8:18 AM   in reply to winstart
    follow this link , it may help:-
    kb2.adobe.com/cps/878/cpsid_87876.html
    Apr 13, 2012 12:02 AM   in reply to winstart
    then there is something in your document which might be causing the issue...
    try and isolate the problem by hiding the layers first ,
    ex:- you have 2 layers then hide one and check bu making pdf , if it works then the issue is in that layer which is hidden
    once you wll find the layer you can locate the object on the layer causing this issue.
    and Is it possible to share the file ....
    Apr 13, 2012 2:16 AM   in reply to winstart
    never faced the issue with layered PDF while exporting but cant say.....there is no harm in trying
    Apr 13, 2012 2:26 AM   in reply to winstart
    Good to know this...Thanks
    Apr 13, 2012 2:59 AM   in reply to winstart
    winstart wrote:
    instead of the layering in pdf now i imported the seperate layers as layers in InDesign. Exporting works fine now, so the failure was made because of the layered pdf
    As far as I know there is nothing inherently problematic about using layered PDFs and exporting, so this may be a problem with that particular PDF file.
    Are you patched to 7.5.2?
    Apr 13, 2012 4:26 AM   in reply to winstart
    Sure. Post a link to it here, and anyone can look, or send it in a private message (click my name or Manish's to go to our profiles) to restrict access.
    Apr 13, 2012 5:59 AM   in reply to winstart
    again, in and of itself, that should not be a problem.
