Design054atAlphagraphics
Dynamic Menu buggy in IE8 and below - How to fix?
Apr 12, 2012 8:40 AM
Tags: #menu-problems #ie-problems
Hi friends,
I have created a site and use the Dynamic Menu module to do the navigation.  They look ok in Chrome and Firefox but when open IE8 and previous versions, the menus are pushed off farther to the right and stick for a long time.  There is also a mysterious horizontal rule above my menu in these versions of IE also!  I cannot figure out how to fix.. however my customer is relatively unhappy.  Perhaps due to my intermediate nature as a web developer
Any clues or suggestions would be fantastic:
www.visionquestdallas.com
http://www.screencast.com/t/iYVPmIvsa
  • Liam Dilley
    Feb 28, 2012
    Apr 12, 2012 3:03 PM   in reply to Design054atAlphagraphics
    Hey there,
    You got to get the coding and css right.
    IE 8 and IE7 have issues with how it renders stuff, IE7 does not clear floats correctly for example.
    With a menu you need to ensure the li parent element of dropdowns has a position relative and the ul child is absolute positioned for example. I often see only the latter. Padding will often thow you out for IE7 and IE8 due to their box modal. You should use line height for vertical centering over top bottom padding.
    Apr 13, 2012 6:40 AM   in reply to Liam Dilley
    I've got a similar problem at the moment. But this is with the most basic Dynamic Menu possible (due to probs with Oxo template and floats/backwards compatibility). I may redo the menu later, but for now I just need to get this last bit working.
    So, the submenus aren't appearing directly under their parent item. Plus they change position depending on what browser I'm using, as well as what size the screen is!
    I've fiddled with the offset settings in the Dynamic Menu so that it is approximately right in IE with a maximised window, but it isn't really good enough.
    Is one of the styles somehow affecting it? It works when I put it on a blank page:
    http://www.f2fcommunications.com.au/test1.html
    And in the body of a page based on the template:
    http://www.f2fcommunications.com.au/test2.html
    But not when it's where it's supposed to be!
    Apr 13, 2012 9:51 PM   in reply to Design054atAlphagraphics
    You can do a fair bit within the dynamic menus themselves, have a look at the options.
  • Liam Dilley
    Feb 28, 2012
    Apr 13, 2012 10:48 PM   in reply to Katharine@CCEDesign
    Check out the guide I wrote on V2 stuff here:
    http://forums.adobe.com/docs/DOC-1903
    Apr 19, 2012 10:51 AM   in reply to Design054atAlphagraphics
    I would recommend outputing the dynamic menu in an unordered list. You can do this if you open up the dynamic menu in the back-end and under the menu details, set the menu type as "CSS (HTML Only)". You will have more felxibility when it comes to styling the menu.
    I created an example menu that had a similar style to yours and wrote some CSS if you would like to use that as a starting point for styling the unordered menu list and dropdown. This may not work perfectly with your site but - again - a starting point. You can see what I did here - https://gist.github.com/2421348
    In my example, note that I wrapped the dynamic menu module tag in <div id="menu">
    Let me know where this gets you!
    Carol | www.bcgurus.com/Business-Catalyst-Templates for only $7
  • Liam Dilley
    Feb 28, 2012
    Apr 19, 2012 3:19 PM   in reply to Design054atAlphagraphics
    You need to look at the code examples everyone is giving you and work with your CSS and not the style options in the admin.
