Hi
I am trying to change an existing form (add some code). I tested the code in a new form I create on my computer but when I do the same on a form supplied and created on a different computer the code won't work
What I see is that the form properties of a new form on my computer give Version 9.xxx and on the form that was created on the other computer the Version is listed as 8.xx
Anyone know how I can convert the Version 8.xx file to a Version 9.xx?
Or someone know how to set a EnclosedOption group from optional to required in Version 8? In version 9 I use Gender.validate.nullTest="error" or Gender.validate.nullTest="disabled" but this doesn't work on the old Version 8.xx PDF File.
Help greatly appreciated!
regards
Meir
Solved! Go to Solution.
Total Likes
Reason for difference in behaviour the form is a static pdf where the other is dynamic pdf. The objects are drawn differently based on how the form is saved and rendered. When static the red boxes will not appear when changed dynamically on the fly. However the functionality does work, it does not allow a submit however it is a not as noticeable without the red border as to where the missing information is located.
There was a tag <?originalXFAVersion http://www.xfa.org/schema/xfa-template/2.6/ LegacyEventModel:1 LegacyRendering:1?> that when it exists causes the form to behave differently.
Total Likes
In Designer go to File -> Form Properties and choose the defaults tab. Change the Target Version of the from from Acrobat 8 and later to Acrobat 9 and later.
Once this is change the XFA version of the form has been updated. If you still have issues then, you may also need to go the XML Source view near the end of text you may see an element similar to this, the version number may be different. You can remove this line
<?originalXFAVersion http://www.xfa.org/schema/xfa-template/2.6/?>
Once you move back to the Design View you will be prompted to save.
Total Likes
Jenn Hi
Thanks for the response. I did change the Target Version and that didn't help. I tried to go to the XML Source View but after about 5 mins the application goes into "Not Responding". The form is pretty full (6 pages) and over 400 fields! Maybe Im just not giving it enough time to open the XML View?
Any other suggestions?
Regards
Meir
Total Likes
If you save the file as xdp you can simply open the xdp in any text editor like wordpad, notepad. Make the change there and save and try again.
If there are a lot of objects/pages in the xdp there can be many lines in the xml source which could be why it is taking a long time.
Total Likes
Hi Jenn
Did as you suggested to xdp deleted the originalXFAVersion (found it listed twice) resaved the xdp. Opened and saved it as PDF in LiveCycle but still no luck!
Thanks for the help so far any other ideas greatly appreciated!
Regards
Meir
Total Likes
Can you attach or upload your form to Acrobat.com so that I can take a look at the form?
Total Likes
Where can i upload it to? Don't see an Attach option here
Meir
Total Likes
Total Likes
Jenn
thanks for the help. Its working perfectly now!
Keep up the good work
Meir
Total Likes
Jenn Hi
Two more questions if i may.
In the Dynamic version that you sent me we ended up with the entire ExclusionGroup with a large red box around it where in the static each option used to have the Red instead. And it seems to be a very thick red box.
1) Is there anyway to control the width of the Red Box?
2)I switched the version that you sent me back to "Static" and then in the verification options added "color fields" and this gives us the functionality that we originally wanted.
The challenge with this solution is that the "page # of ##" on the master page doesn't render.
Any suggestions would be appreciated.
Regards
Meir R.
Total Likes
