FMS 4.5.1 Windows 2008 SP2 (64bit).
I've searched everywhere for a possible solution to this, so my apologies if this has been asked before and my thanks for any potential help that anyone can offer to help resolve this.
We are deploying Adobe Flash Media Server 4.5.1 on a new server but Apache does not work (does not serve html files or stream Quicktime H.264 files).
Assorted Problems & Error messages:
1. The webroot/index.html page loads locally, but the HLS/HDS streams result in a 2032 error.
2. The webroot/index.html page does not load from external locations:
http://63.116.232.5/index.html (does not load externally).
http://63.116.232.6/index.html (our old server, FMS 4.0 and Windows 2003). Everything on this server works, the 2 major differences being that it is running FMS 4.x on Windows 2003.
Some RTMP streaming works externally and internally (f4v files):
FMS does not stream Quicktime H.264 files even though f4v files work.
New server (does not work): http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232 .5/vod/mp4:Basketball.mov
(f4v works): http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232 .5/vod/mp4:sample1_150kbps.f4v
Old server (Quicktime/H.264 file works): http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232 .6/vod/mp4:Basketball.mov
Apache does not serve Quicktime/H.264 files: I made sure that Apache had all of the correct mime types specified.
Error messages and attempted solutions:
a. httpd.exe: Could not determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
2. FMS master.log file
a. FMSHttpd -k start returned 1:
Solutions: http://wiki.apache.org/httpd/CouldNotDetermineServerName
1a: Edited httpd.conf file to include ServerName 63.116.232.5
1b: The presence of this error message also indicates that Apache httpd was unable to obtain a fully-qualified hostname by doing a reverse lookup on your server's IP address.
In order for the server to accept external connections a reverse DNS lookup needs to be created. I created a reverse DNS lookup and edited the /etc/hosts file to include the IPaddress, Fully Qualified Domain Name (FQDN), shortname.
This is the format suggested by the article:
127.0.0.1 localhost.localdomain localhost foo.example.com
Running the nbtstat -a 63.116.232.5 command on the machine results in the following:
WIN-8AIHI2J0524<00> UNIQUE Registered
THS-LIBRARY-VOD<00> GROUP Registered
THS-LIBRARY-VOD<1C> GROUP Registered
WIN-8AIHI2J0524<20> UNIQUE Registered
THS-LIBRARY-VOD<1B> UNIQUE Registered
So the FQDN = WIN-8AIHI2J0524.Ths-library-vod.local
I edited the /etc/hosts to the following (with versions using the local host ip 127.0.0.1 and the external ip address, IPv4 is being used):
63.116.232.5 WIN-8AIHI2J0524.Ths-library-vod.local
# The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
I've also read Adobe's port configuration articles and changed the ports that Apache and FMS use as specified in the conf/fms.ini file, but nothing has worked so far. I restored everything to the original settings until I can find out exactly how to fix this.
Thank you.
Did you properly installed the server or
1. Overritten the old server with the new one.
2. Just untar the linux installer zip and copied them.
The httpd.conf issue happens to me, in case I just do unzip of the bundle on linux and start using it.. If I do proper ./installFMS and then use the fms from installed path, then it works fine..
I uninstalled FMIS and re-installed everything (Windows 2008 SP2 64bit, FMIS 4.5.1).
1. The Apache errors are gone (FMSHttpd -k start returned 1: & Could not determine the server's fully qualified domain name errors not coming up).
2. I am now getting the following error in the edge log: Failed to create listener for adaptor _defaultRoot_, IP , port 80: TCCommBridge::createListener 0.0.0.0:80/v4: bind failed!!!.
Same problems persist (IPs .5 and .6 are two different servers):
New FMS 4.5 server: http://63.116.232.5/index.html (does not load externally).
Old FMS 4.x server: http://63.116.232.6/index.html (everything works)
Errors from the webroot/index.html page:
Error # 2032 when trying to play HLS & HDS files (added mime types to Apache).
RTMP files play fine.
RTMP streaming works externally, but H.264 files do not work for some reason:
http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232 .5/vod/mp4:sample1_150kbps.f4v works, but my own files do not work, e.g.,
This file works with the old server, so I don't think that it is a problem with the file itself:
HLS and HDS streaming from the webroot folder does not work. RTMP streams f4v files, but not H.264 .mov files.
I have no idea why this is happening and therefore no clue on how to fix it.
Thank you for the help Mr. Goel.
Narrowed it down to this:
1. Fixed: Got Apache to serve html pages to external connections: http://63.116.232.5/index.html
2. FMS does not stream Quicktime/H.264 files, f4v files work.http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232 .5/vod/mp4:sample1_150kbps.f4v
Re-encoded the file in Media Encoder. Changed extension from .f4v to .mov and the file works. This is therefore a problem with the way the files are being encoded by Compressor. I don't know what the difference is between FMS 4.x and 4.5 when it comes to this issue since the .mov files from Compressor work with no problem with 4.x.
http://www.librarymedia.net/flash/player.html?source=rtmp://63.116.232 .5/vod/mp4:Basketball2.mov
I don't want to use Media Encoder because:
Any ideas, anyone?
Thanks.
The problem has returned.
Streams result in the following error: server not found rtmpt://63.116.232.5.80/vod/ (error from http://www.librarymedia.net/Pages/THS-Graduation2012.html , works fine internally).
80/vod suggests that there is a problem with port 80. I'll look at the conf files and change the port settings for FMS and Apache (what I did above).
Any help would be greatly appreciated.
Can you just try a telnet from any external client to the public IP of the FMS machine and port 80 just to ensure there are no firewall issues happening?
Also, can you check if you have not set any domain restrictions say in allowedSWFdomain.txt & allowedHTMLdomains.txt if you are using live or vod sample applications?
Apurva
First, I should let you know what I've done:
a. rootinstall/Apache2.2/conf: Changed the line Listen 8134 to Listen 80.
b. rootinstall/conf/fms.ini: Removed 80 from the ADAPTOR.HOSTPORT parameter, ADAPTOR.HOSTPORT = :1935.
Windows: Telnet commands:
o 63.116.232.5 80
o 63.116.232.5 1935
Results: Could not open connection to the host on port 80 or 1935: Connect failed.
OS X: telnet 63.116.232.5 80
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>501 Method Not Implemented</title>
</head><body>
<h1>Method Not Implemented</h1>
<p>to /index.html not supported.<br />
</p>
<hr>
<address>Apache/2.2.21 (Win32) DAV/2 Server at WIN-8AIHI2J0524.Ths-library-vod.local Port 80</address>
</body></html>
Thank you for your help Mr. Udaykumar.
Hi Carlos,
I'm able to telnet your machine on port 80 but connection fails on port 1935. Can you please reconfirm that port 1935 is open?
You need to add port 80 in Apache and not replace it. So your httpd.conf will have :
Listen 80
Listen 8134
Your fms.ini should have :
Once you make these changes, please restart your server and then try.
If you're unable to access anything on the server, could you please check the Master log under <root_install>/logs for any errors and check what process is bound to those ports.
Ms Apurva ![]()
Ms. Apurva
I changed the files back as you suggested (the failure was occuring with the default settings) and our admin assured me yesterday that the ports that I inquired about were open. I'll ask him again.
The telenet command for both ports 80 and 1935 result in Connect failed for me. I'll check Windows Firewall (turned off) and McAfee to see if there is anything there blocking ports.
Confirm that external connections are blocked: 63.116.232.5/index.html (does not open outside of localhost). No problem accessing with our old server (63.116.232.6/index.html).
I ran this command in nmap and here are the results (11 ports closed): nmap 63.116.232.5 -Pn80
Starting Nmap 6.01 ( http://nmap.org ) at 2012-07-06 08:29 Eastern Standard Time
Nmap scan report for 63.116.232.5
Host is up (0.00092s latency). nmap -p 80 says that the host is down (for both ports).
Not shown: 988 filtered ports
PORT STATE SERVICE
1720/tcp open H.323/Q.931
6000/tcp closed X11
6001/tcp closed X11:1
6002/tcp closed X11:2
6003/tcp closed X11:3
6004/tcp closed X11:4
6005/tcp closed X11:5
6006/tcp closed X11:6
6007/tcp closed X11:7
6009/tcp closed X11:9
6025/tcp closed x11
6059/tcp closed X11:59
Nmap done: 1 IP address (1 host up) scanned in 5.72 seconds
Host status: up
open ports: 1
filtered ports:988
Closed ports: 11
ipv4:63.116.232.5
ipv6: not available
MAC: not available.
Master log file:
| 2012-07-06 | 09:22:41 | 6712 | (i)2581173 | FMS config <NetworkingIPv6 enable=false> | - |
| 2012-07-06 | 09:22:41 | 6712 | (i)2581173 | FMS running in IPv4 protocol stack mode! | - |
| 2012-07-06 | 09:22:41 | 6712 | (i)2581173 | Host: WIN-8AIHI2J0524 IPv4: 10.250.10.1 | - |
| 2012-07-06 | 09:22:41 | 6712 | (i)2571011 | Server starting... | - |
| 2012-07-06 | 09:22:46 | 6712 | (i)2581413 | H:\Program Files\Adobe\Flash Media Server 4.5\Apache2.2\bin\httpd -f ./conf/httpd.conf -d "H:\Program Files\Adobe\Flash Media Server 4.5\Apache2.2" -n FMSHttpd -k start returned 0: | - |
| 2012-07-06 | 09:22:46 | 6712 | (i)2581224 | Edge (1508) started, arguments : -edgeports ":1935" -coreports "localhost:19350" -conf "H:\Program Files\Adobe\Flash Media Server 4.5\conf\server.xml" -adaptor "_defaultRoot_" -name "_defaultRoot__edge1" -edgename "edge1". | - |
| 2012-07-06 | 09:22:46 | 6712 | (i)2571111 | Server started (H:\Program Files\Adobe\Flash Media Server 4.5\conf\server.xml). | - |
edge log:
| 2012-07-06 | 09:22:46 | 1508 | (i)2581173 | FMS detected IPv6 protocol stack! | - |
| 2012-07-06 | 09:22:46 | 1508 | (i)2581173 | FMS config <NetworkingIPv6 enable=false> | - |
| 2012-07-06 | 09:22:46 | 1508 | (i)2581173 | FMS running in IPv4 protocol stack mode! | - |
| 2012-07-06 | 09:22:46 | 1508 | (i)2581173 | Host: WIN-8AIHI2J0524 IPv4: 10.250.10.1 | - |
| 2012-07-06 | 09:22:47 | 1508 | (i)2631174 | Listener started ( _defaultRoot__edge1 ) : localhost:19350/v4 | - |
| 2012-07-06 | 09:22:48 | 1508 | (i)2631174 | Listener started ( _defaultRoot__edge1 ) : 1935/v4 | - |
| 2012-07-06 | 09:22:49 | 1508 | (i)2631174 | Listener started ( _defaultRoot__edge1 ) : 10.250.10.1:19350 (rtmfp-core)/v4 | - |
| 2012-07-06 | 09:22:49 | 1508 | (i)2631174 | Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:19350 (rtmfp-core)/v4 | - |
| 2012-07-06 | 09:22:49 | 1508 | (i)2631509 | Public rtmfp-core addresses for listener _defaultRoot__edge1 are: 10.250.10.1:19350;127.0.0.1:19350 | - |
| 2012-07-06 | 09:22:49 | 1508 | (i)2631174 | Listener started ( _defaultRoot__edge1 ) : 10.250.10.1:1935 (rtmfp)/v4 | - |
| 2012-07-06 | 09:22:49 | 1508 | (i)2631174 | Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:1935 (rtmfp)/v4 | - |
Not sure what to do.
Thanks.
