Streaming for Android devices using Amazon AWS and Adobe FMS 4.5
Apr 11, 2012 8:37 AM
Tags: #adobe #android #live_streaming #fms_4.5 #amazon #aws
I have created a live stream using Amazon Web Services and Adobe Flash Media Server 4.5.
AWS provides me with both a .f4m and .m3u8 file, to use in  <object><embed> and  <video> tags, respectively.
The .f4m loads fine on my desktop browser, and the .m3u8 file loads fine on my iOS device. However, my Android devices will not load either file.
What code/solutions are there to get this to play on Android devices?
My current .f4m code (retrieved from http://www.osmf.org/configurator/fmp):
<object width="600" height="409">
    <param name="movie" value="http://fpdownload.adobe.com/strobe/FlashMediaPlayback_101.swf"></param>
    <param name="flashvars" value="src=http%3A%2F%2F<myinfo>.cloudfront.net%2Fhds-live%2Flivepkgr %2F_definst_%2Fliveevent%2Flivestream.f4m"></param>
    <param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param>
    <embed src="http://fpdownload.adobe.com/strobe/FlashMediaPlayback_101.swf" type="application/x-shockwave-flash" allowscriptaccess="always"
                allowfullscreen="true" width="600" height="409" flashvars="src=http%3A%2F%2F<myinfo>.cloudfront.net%2Fhds-live%2Flive pkgr%2F_definst_%2Fliveevent%2Flivestream.f4m">
    </embed>
</object>
My current .m3u8 code:
<video src="http://myinfo>.cloudfront.net/hls-live/livepkgr/_definst_/liveevent/livestream.m3u8 " height="300" width="400"> </video>
    Apr 13, 2012 12:47 AM   in reply to JohnASmith21
    Hi John,
    I have just tried with an OSMF player on my android device and was successfully able to ply one of the hds vod streams that ships with FMS4.5.
    I have created this player once for my own testing purpose, so when I have provided the url like - "http://<myamazoninstance>/hds-vod/sample1_150kbps.f4v.f4m", it started stremaing without issues.
    Although, so far I havent tried making a html, hosting on a webserver and then finding the issue.
    What I will suggest you to directly play the stream on your android device using the swf file and see if it plays fine.
    Just in case if you like I can share the air apk I have used to test this functionality.
    Shiraz Anwar
    Apr 13, 2012 1:33 AM   in reply to Shiraz Anwar
    Few additional things which I just came across while setting up for live stream on my Android from AWS are as follows:
    1. for the first time when I tried to run the live stream on my android app, it didnt run at all and I thought your concerns are valid for an instance :-) .
    2. Later, I killed the application from task manager, restarted it cleanly and again provided the url and it streamed without issues.
    Please also ensure that:
    - You had put a crossdomain.xml file under <fmsinstalldirectory>/webroot folder.
    - You have provided the correct stream name in the <media> tag in Manifest.xml file inside <fmsinstalldirectory>/livepkgr/events/_definst_/liveevent folder
    (hopefully you have done it since you are already playing it on PC)
    You may also like to cehck the apache logs inside <fmsinstalldirectory>/Apache2.2/logs/access_logs folder to find whether your Android device request is reaching to the server.
    Hope these steps will help you in osloating the problem.
    Shiraz Anwar
    Apr 16, 2012 11:09 PM   in reply to JohnASmith21
    In context of AWS, you may like to check following locations:
    fms logs - /mnt/logs - here you will get master.00.log, access.00.log, edge.00.log and other applications and admin logs
    fms application folder - /mnt/applications - location to put your fms applications
    fms webroot folder - /mnt/webroot folder
    default fms install directory - /opt/adobe/fms
    fms conf file locations - /opt/adobe/fms/conf - here you will find all the xml files
    Apache directory - /opt/adobe/fms/Apache2.2
    Apache logs directory  - /opt/adobe/fms/Apache2.2/logs - for HDS/HLS logging purpose
    Hope this will help.
