siwybiwy
Redefining styles in another way
Apr 12, 2012 8:47 AM
A friend of mine just asked me a very interesting question. If you had some text that you manually styled (ie not a style yet), and you had Heading 1 in your styles palette already, can you select the new manually styled text and say that it is NOW Heading 1 with the new attributes? Meaning Heading 1's style gets replaced with whatever the style of my manually styled text is.
Thank you in advance for your help.
We're both using InDesign CS4.
    Apr 12, 2012 10:12 AM   in reply to siwybiwy
    If you originally had the text styled as Heading 1 but you modified it in any way, you can simply use the panel dropdown and select "redefine style".
    However, if you started from scratch and so the type is in "[Basic Paragraph]", you would need to create a new style, call it heading 2 then delete heading 1 and replace with heading 2. You can then rename the style if you wanted.
    Apr 12, 2012 10:41 AM   in reply to siwybiwy
    or copy a few letters of the "different style"  paste into text with the Heading 1 style, and redefine style. Delete pasted text.
    G
    Apr 12, 2012 12:47 PM   in reply to siwybiwy
    siwybiwy wrote:
    ...but I was looking for a shorter solution.
    ...forces me to style some text with Heading first, which also takes time
    I don't understand why you think a script will help in this case. All the solutions above can be done with only a few clicks of the mouse and are extremely efficient. It might just force you to reconsider how you work in the future.
    Apr 12, 2012 12:52 PM   in reply to siwybiwy
    actually the best way to do this: more ellegant: is...
    Create a new style with the manually styled text. Call it for eg: Heading New.
    With nothing selected click the Heading 1 style in the styles panel. Click delete, a dialogue box will pop up and then select replace with Heading New.
    G
  • lilia@
    Jan 31, 2012
    Apr 12, 2012 1:07 PM   in reply to siwybiwy
    Find/Change > Find what: local formatting / Change to: Heading 1 paragraph style
  • lilia@
    Jan 31, 2012
    Apr 12, 2012 1:16 PM   in reply to siwybiwy
    lol... no anger here,,, It's a great idea but can't be done as everyone has said... unless you use a script. But I think Grants ideas were great.
    Apr 12, 2012 1:21 PM   in reply to siwybiwy
    Basically, everyone is making multi-step suggestions that could be, as lilia observes, reproduced in a one-click script. There is no one-step way to achieve what you're asking about in InDesign.
    (I run through one of these multi-step style redefinitions hundreds of times a day, but I do it fast enough on the keyboard alone that wrapping these steps up into a scripe would not get me any advantage in terms of speed. Any benefit from wrapping these steps up into a script would be eaten up by the step "remove hands from keyboard, grope for mouse, open Script panel, click on script.")
