There are 3 designers that are having the same issue out of many in the dept., each of them when printing a specific document from the same printer part of the image is not printed correctly, it looks corrupted or misaligned. When sending the image to another designer the document prints out perfectly. I reinstalled the printer drivers, and matched up the drivers used for the printer. I think this is a setting issue, but i don't have a clue which setting this would be.
There are two documents. Document A skews only part of the image ever time it's printed from each of the 3 new designers, so say the page is 8/12 by 11 only 2 inches in the document prints out incorrectly. Document B when part of the image is rotated it shows normal but prints a white patch at an angle where the image has been rotated. Has anyone had a similar issue? Also I know there is a workaround of exporting it to a .pdf, but that is not an option for the designers unfortunately.
I had one of the designers replace the image with another image and it printed out perfect. Could this be a corrupt image or a setting for a image in InDesign? Also when another designer that is not one of the 3 that are having this issue prints out the origional document it prints out perfect. Drivers and adobe products are the same.
Yes, it could be a poorly constructed image; hence the question what is the image type? You noted InDesign/pdf. I'm assuming it is not an InDesign image, as there is no such animal (aside from snippets, linked ID doucuments, groupd elements...)
Have you tried the advice I posted twice > Send Data > All
Can you clarify what exact image type is not imaging;
A tiff image in the same document prints incorrectly on 3 stations, but correctly on another station; and Image Data is set to Send All...
Print drivers are up to date...there is an option in the Print Dialog which could be set differently on the same Graphics tab > Data Format ASCII is the default, Binary has limited support and may not be available.
I may not be able to offer much further; tiff is a pretty stable format, to my knowledge, but I would open the tiff in Photoshop, save as a Photoshop file and place that in ID, than Save as a copy back to tiff to re-fry the image.
We tried to set Data Format ASCII and that did not work either, the designer also saved the image/file that was printing corruptly to a .psd file and that did not work either. I am wondering if there is a problem with the program specifically. What really puzzles me is that the 3 people that had Adobe CS5 installed on recently are having the issue. There has to be a correlation between the 3. The print drivers are the same, and they are all on Adobe CS5.. Anyone else have any thoughts?
You might reset the users preferences - if they have modified/created their workspace, created unique keyboard shortcuts or a few other items, these customizations will be lost. This article details how to back those up in detail.
http://forums.adobe.com/thread/526990
As their IT, you could create a new user profile or user account to the workstation.
If this is an isolated incident, you might move on.
@Bob, I print, out of necessity, hundereds of files annually straight to an imagesetter. Acrobat does not have the features available, and the OP stated that pdf is not an option for all users. (Standalone product?; yes, Reader might suffice)
@Bob, have I missed anything relevant?
I read over the link you posted Daniel, but unfortunatly that did not work. I also had the user log into another workstation and they were able to print just fine. This is not a preferances due to resetting her preferances to default. I will keep hunting for answers, i will reorganise and layout whats been done and where to go from here. The user is ready to give up but I am not...
I asked the design person to save the file to her desktop, I logged in and was able to print the image out perfectly. I think this is an issue dealing either with the image or the link for that image. Has anyone heard of images or links to images causing printing to not be printed correctly.
I meant replace it with itself. Sometimes frames get corrupt for no apparent reason and replacing them solves oddities. What I find very strange though, is that the smae file prints OK for some users but not others. That usually indicates a problem in the prefs or the user profile. Does it work on the same machine from a new user account? That would tend to comfirm a user problem.
What's the OS?
The OS is win7, looks like the culprit is a print driver, I’m looking for HP universal Print Driver PCL6 version 12/4/2009, 61.94.3.37. The current one being used on the systems not working is HP universal Print Driver PCL6 version 8/17/2010, 61.107.4.8232.
I installed the 12/4/2009 print driver for this, and went to printers and right clicked on printer properties, I went to advanced, clicked new driver and then clicked windows update. (HP.com stated this has no specific driver and to use the windows update to get the driver) I used the specific printer model, and I was able to print the document normally. I used a PS driver instead of a PCL driver. The only problem with this is when i go to print it says "The following fonts aren't currently available: but I’m assuming that is due to the fact that I had the designer save the document and the links to one folder so I could access the content, and those specific fonts are in the folder.
Does anyone have any thought on this?
I found a Post Scrip printer driver for the specific model # we are using prints out the documents just fine.
For PCL (Printer Control Language) the drivers for this language utilize the printer hardware for creating some of the printed data, usually graphics data such as fill areas, underlines or fonts. This allows the computer to process the print job quickly and efficiently. The printer is then responsible to complete the creation and processing of page data.
PS (Post Script Language )It is used heavily in Macintosh platforms and for graphic applications in several platforms. Unlike PCL, Postscript is device independent. This means that the Postscript language creates all of the print data and does not rely on the printer for print data. This allow the output to be consistent when printed on more than one type of printer or print device. Specifically, the graphic objects will be consistent and in some cases of higher quality than PCL.
So as it seems this is the answer to my issue.
http://www.laserquipt.com/support/idx/0/063/article/PCL-vs-Postscript. html
