Flyrodder1955
Is there a way to justify text in Photoshop Elements?
Apr 12, 2012 7:32 AM
Tags: #text #justify
I am trying to justify text in Photoshop Elements 10 but can't find any place that I can do that.  Can I justify text and, if so, how?
  • 99jon
    Jan 6, 2010
    Apr 12, 2012 7:42 AM   in reply to Flyrodder1955
    Only left, right or center alignment. I usually copy from a word processor document or the net, but I still have to use the tab key. But it works.
    Apr 12, 2012 9:38 AM   in reply to Flyrodder1955
    Using a type tool, click the Align pop-up menu and select any of the following:
    Left Align
    Aligns the left edge of each text line in the layer to the initial cursor position.
    Center
    Aligns the center of each text line in the layer to the initial cursor position.
    Right Align
    Aligns the right edge of each text line in the layer to the initial cursor position.
    Apr 12, 2012 11:12 AM   in reply to Flyrodder1955
    Suggest that you type the text, aligned justify mode, in WORD.
    Then, import picture or graphic enhanced in Elements, into WORD.
    Apr 12, 2012 2:01 PM   in reply to Flyrodder1955
    As has been explained, you can't justify text in PSE.
    Any project that requires such formatting should be done in a word processing program or a page layout program.  You can obviously use PSE to edit the images used in the project.
    Ken
    Apr 12, 2012 6:06 PM   in reply to Flyrodder1955
    If you paste the text into a paragraph box, try one of these keyboard shortcuts while all of the text is selected:
    Ctrl+Shift+J (Cmd-Shift-J)
    or
    Ctrl+Shift+F (Cmd-Shift-F)
    Apr 12, 2012 7:01 PM   in reply to R_Kelly
    Excellent!  Thanks for that tip.
    Ken
    Apr 12, 2012 9:20 PM   in reply to photodrawken
    Your welcome.
    If you had a paragraph panel in elements (like photoshop) then these are the buttons that those shortcuts correspond to:
    (unfortunately the other two justify options don't have any default keyboard shortcuts in elements nor photoshop, as far as i know)
    Apr 13, 2012 12:06 AM   in reply to R_Kelly
    Well, I should have checked this first, but my favourite add-in, Elements+ (http://elementsplus.net/) will do all the text alignments:
    Ken
