How can i change the transformation handles in the options menu for the menu-widget from height to w
Apr 12, 2012 6:14 AM
How can i change the transformation handles in the options menu for the menu-widget from height to width? At the moment is it only possible for me to change the height of the menu-widget because the transformation handles voor the width are not selected. In the Options-panel i see next to Item Size: Uniform Height etc. How can i change that to Uniform Width?
    Apr 12, 2012 2:24 PM   in reply to beterlaatdannoglater
    The option to uniform width is available for Horizontal Menu type widget, http://project02.businesscatalyst.com/jing/2012-04-13_0250.png
    If you are using the Vertical Menu type, then indeed that option is not yet available. You can add it as an idea or feature request for the next releases.
    Apr 13, 2012 11:59 AM   in reply to beterlaatdannoglater
    Try to change the menu direction as shown in this screen shot, http://project02.businesscatalyst.com/jing/2012-04-14_0027.png
    Apr 13, 2012 6:35 PM   in reply to beterlaatdannoglater
    Hello,
    The trick is to set the top and bottom padding for BOTH the text frame and container (and menu) to zero - wallah, you can shrink the height of the menu/container to zero.  Same with the horizontal menu - make sure the L and R paddings are set to zero and shrink that width as much as you want.
    Kate
