returning to a random cordinate?
Apr 12, 2012 3:05 PM
basically i have an object set to appear at random co ordinate
start_x = random(800)
start_y = 300 + random(500)
sprite(ch).locH = start_x
sprite(ch).locV = start_y
when moving the object and then detect a collision with another object i want it too return to that random coordinate created above so far i can only set it
eg sprite(ch).locH = -1000
    Apr 13, 2012 12:32 PM   in reply to elimann
    It's going to depend on your code but you just need to store the location in either a user-defined sprite property (best method) or a global variable. Where is this code found that you have posted, in a sprite behavior?
    Apr 13, 2012 12:39 PM   in reply to elimann
    I am guessing your code is not in a sprite behavior, but that it is in a movie script somewhere. If that is the case it could look like this:
    global gRandomStartingLoc
    gRandomStartingLoc = point(random(800), 300+random(500))
    sprite(ch).loc = gRandomStartingLoc
    Then after the collision just reset the loc again
    Apr 13, 2012 6:11 PM   in reply to elimann
    Actually it would, but it would be better to use a sprite property. Same code though.
    property pRandomStartingLoc
    pRandomStartingLoc = point(random(800), 300+random(500))
    sprite(ch).loc = pRandomStartingLoc
    on CollisionHandler me
         sprite(spriteNum).loc = pRandomStartingLoc
    end
    So is this behavior attached to sprite(ch) ? If so, there's not need to reference the hard coded sprite name. You remove the hard coded sprite name so that it could be applied to another sprite and not need modifying. It makes for more "reuseable" code.
    property spriteNum, pRandomStartingLoc
    end
    Going a step further, suppose you have multiplle sprites with similar behavior, except their random starting loc different. You can remove all hard coded values. This behavior could be applied to any number of sprites without changing the code. Each would be customizable through the parameters dialog.
    property spriteNum, pRandomStartingLoc, pMaxRandomX, pMaxRandomY, pXmodifier, pYmodifier
    on beginSprite me
      pRandomStartingLoc = point(random(pMaxRandomX) + pXmodifier, random(pMaxRandomY) + pYmodifier)
    end
    end
    on getPropertyDescriptionList
      description = [:]
      addProp description,#pMaxRandomX, [#default:800, #format:#integer, #comment:"Max Random LocX"]
      addProp description,#pMaxRandomY, [#default:800, #format:#integer, #comment:"Max Random LocY"]
      addProp description,#pXmodifier, [#default:0, #format:#integer, #comment:"Add this amount to the random LocX"]
      addProp description,#pYmodifier, [#default:0, #format:#integer, #comment:"Add this amount to the random LocY"]
      return description
    end
    Apr 15, 2012 7:11 AM   in reply to elimann
    For fun I modified Mister MUX's behavior to pick random locations with no overlapping sprites.
    This is accomplished by adding a global list of rects that are in current use, and making sure no new sprite rects overlap any rects in the list.
    The global list is initialized in a Movie script:
    global gOccupiedRects -- list of rects that are currently used by sprites
    on prepareMovie
      gOccupiedRects = []
    end  prepareMovie
    And the modified behavior is:
    property Sp  -- this sprite
    global gOccupiedRects -- list of rects that are currently used by sprites. Cleared in movie script
    on beginSprite me
      Sp = sprite(spriteNum)
    Sp.loc = pRandomStartingLoc
      cnt = 0
      repeat while (me.overlaps(Sp.rect))
        cnt = cnt + 1
        if cnt > 10000 then  -- don' t want to get stuck in an infinite loop
          put("Can not find non-overlapping location to place sprite. Aborting")
          abort()
        end if
        -- try new random location
      end repeat
      gOccupiedRects.add(Sp.rect)
    end beginSprite
    -- check if testRect intersects/overlaps any rect in gOccupiedRects list
    on overlaps me, testRect
      EmptyRect = rect(0,0,0,0)
      repeat with aRect in gOccupiedRects
        if (aRect.intersect(testRect) <> EmptyRect) then return true  -- true means overlap
      end repeat
      return false
    end overlaps
    end CollisionHandler
      description = [:]
      return description
    end getPropertyDescriptionList
