LarryKaufmann
Image Shifts When Using Shared Printer
Apr 12, 2012 3:02 PM
Tags: #crop #print #shared
OS 10.6.8
Acrobat Pro 9.5.1
Printer: Canon Pixma 4800 ip4800
As far as I know, all drivers are up to date.
Printer is connected to an iMac and is set to allow sharing.
When printing a .pdf from another Mac (wirelessly via AirPort), the image is shifted slightly (approx 3/8") to the right and down on the printed sheet, cropping content.
All other remote printing is OK (including from other Adobe CS5 applications). I can also remote print the .pdf correctly using Apple's Preview application. Printing is also OK if printed from the iMac that the printer is connected to. Only time there is an issue is: Shared printing a .pdf using Acrobat.
    Apr 18, 2012 2:09 AM   in reply to LarryKaufmann
    Dear Larry,
    Thanks for reporting the problem. You mentioned that page content is getting shifted by around 3/8 inches when printed using Mac Airprint using Acrobat which resulted in clipping of some of the content and other applications print fine.
    Could you please pass on the same pdf to me as well? Although, it doesnot look dependent on any particular pdf but I would like to analyze certain behavior with the pdf you are using.
    Please also confirm that you have not printed with "None" pagescaling option when you observed this.
    Thansk,
    Atul
