Bizarre page behaviour!
Apr 12, 2012 4:01 PM
Tags: #template_misbehaving
BC is injecting an extra header into editted and re-uploaded pages.
The problem seems to disappear when I opt not to use a template.
A very strange problem with an even stranger fix! Is anybody else experiencing the same?
I should also mention that I was earlier locked out of the system (this one's a long story but is sort of ressolved now).
  • Liam Dilley
    Feb 28, 2012
    Apr 12, 2012 4:22 PM   in reply to Dave Black
    Hi Dave,
    If you make a page with no template there is the basic html which is added into that page. If you click the HTML tag at the bottom of the editor you can see that. Then if you select a template it still has that HTML in the editor code which can cause probems.
    If you find this to be the case you can go to the html tab for the editor of the page and remove that body/header html.
  • mario_gudelj
    Oct 13, 2010
    Apr 12, 2012 11:45 PM   in reply to Dave Black
    Hi Dave,
    That does sound weird. can you please check your FTP details for that old site, under the site settings in DW, and make sure that the username has /dw at the end of it?
    Cheers,
    Mario
