JonYoder
Problems with DSLR video and PR crashing
Apr 12, 2012 4:04 PM
Tags: #pro #premiere #windows #quicktime
Hello! I'm a new user to Premiere and am having some problems importing DSLR video (5Dmk3 24p). I've done a lot of searching and have found a few people with similar problems, but I wasn't able to work through figuring it out. So now I'm consulting the best of the best.
My problems: (note: when I say crash, I mean hangs indefinitely. I've never seen an error message through any of this.)
  • Premiere Pro (5.5) sometimes crashes when I import videos. There seems to be certain videos that make Premiere hang but I can't isolate the problem to a file either. One file will make PR crash one time, when I restart the program the same file will import fine. It's quite rare where I can import an entire folder (~20) of videos, but it happens once in a while.
  • When I have all my videos imported, when I open up my project some videos will show as offline. Just like my previous problem, the files change each time I open Premiere. Sometimes when I save the project with these offline clips, PR will crash when I try to close it.
Video of the problem: (pardon my poor TV persona )
My computer: Intel i5, Windows 7 65bit, 16gb RAM, 60GB SSD HD, 1.5TB storage SSD. Premiere is updated (5.5.0 233), I have all the computer/driver updates that I know of.
I've tried reinstalling Quicktime (several times) and also reinstalling Premiere. I've tried changing the scratch disk, the Adobe CS agent said I should import files one by one and from the desktop but to no avail. A work around that kind of works is to import a few files, save, import, save, etc., so that when Premiere crashes, I can keep importing where I left off.
This problem is really bugging me and I would so appreciate it if any of you have some wisdom to share. I read online where someone had a similar problem and ended up reencoding to a different codec as a workaround, but I would rather not have to do that. Thanks you!
    Apr 12, 2012 4:48 PM   in reply to JonYoder
    SSD for storage MAY be your problem...
    SSD and Video Editing http://forums.adobe.com/thread/902915?tstart=0
    Apr 17, 2012 12:40 PM   in reply to JonYoder
    We've seen some cases where files from the 5D MKIII do not import properly. (The MKIII was released after CS5.5, and uses a different format from the 5D MKII) As a workaround, you can rename the file extension (you can automate this through Adobe Bridge if you have a lot of clips) from .MOV to .MP4. This will cause Premiere Pro to process the files with a different import module that will handle the file correctly.
