I'm trying to remove numbers from a baseball box score pulled from the Internet.
The file has 10 numbers across separated by tabs and I only need six of the numbers not all 10
St. Lucie Mets
Player,Pos AB R H 2B 3B HR RBI BB SO AVG
Daniel Muno, 2B 4 1 1 0 0 1 1 0 2 .259
Robbie Shields, DH 4 0 2 1 0 0 0 0 1 .471
This GREP search works in FindChange in InCopy/InDesign (using CS4)
(\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d)
This works in the Change field
$1 $2 $3 $7 $8 $9
However, when I try to add this to a FindChangeByList script, it generates an error. So my syntax, logic or both is flawed.
What should I do to fix it?
grep {findWhat:"(\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d) (\t\d)"} {changeTo:"$1 $2 $3 $7 $8 $9"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false} Find all double spaces and replace with single spaces.
Thank you,
Keith
Hi Jongware,
Thank you for the reply.
I tried the double slashes and get an Error 25. So something I'm doing in the Search/Replace portion isn't working.
However, I did have success with changing a style by using a GREP search. The line below works with the double slashes, just not the Find/Change lines:
| grep | {findWhat:"\\t\\d\\t\\d\\t\\d\\t\\d\\t\\d\\t\\d\\t\\d\\t\\d\\t\\d"} | {appliedParagraphStyle:"Z BB Box Exp Batting 07T"} | {includeFootnotes:true, wholeWord:false, caseSensitive:false} | //Changes style |
