Can't launch updated Adobe Reader v10.1.3 in Firefox v3.6.28 in Mac OS X 10.5.8?
Apr 11, 2012 7:41 PM
Hello.
Is it me or does the newly updated Adobe Reader v10.1.3 does not load from Firefox v3.6.28 in Mac OS X 10.5.8? This is after I click on any PDF links on a web site. Safari had no problems though!
Thank you in advance.
    Apr 12, 2012 8:33 AM   in reply to AntD00d
    Same issue here, with OS X 10.7.3, Firefox 3.6.28 and Reader 10.1.3 all I get is a blank window where the PDF should be.  I can disable the add-on but then it pulls me out of my browser.  I have tried deleting the NPAPI plugin and reinstalling both Adobe and Firefox but still no luck.
    Apr 12, 2012 12:53 PM   in reply to AntD00d
    Experienced same problem immediately following Adobe Acrobat update installation (v10.1.3). Also experienced when trying to view attached PDF files within the Zimbra email program from vmware in both the desktop application (Zimbra Desktop 7.1.4) as well as the web version when launched within Firefox.
    Apr 12, 2012 1:49 PM   in reply to AntD00d
    It seems to be an issue with the NPAPI plugin Adobe released, it just isn't working.
    We were able to get it working with 'PDF Plugin for Firefox on Mac OS X'.  Based on posts on the Mozilla forums there are other plugins that work.  Some posts indicate it is a compatiblity issue with Firefox 3 but we tested with Firefox 5 and Firefox 10 and it didn't work there either.
    Apr 12, 2012 10:02 PM   in reply to AntD00d
    AntD00d wrote:
    http://helpx.adobe.com/content/dam/help/attachments/Acrobat_Reader_Rel easeNote_10.1.3.pdf says it dropped old Firefox versions.
    It's not about that, I think, as I got the exactly same bug with Firefox 12.0 / OS X 10.7.3 after the last Adobe Reader update.
    However, the release notes are interesting, see p. 6: "If you still require a 32-bit solution, this update also supports Mozilla Firefox for Macintosh when it is opened in 32-bit mode.
    So, it seems that the last update is pushing the inline viewer (NPAPI?) plugin to 64-bit Firefox, even that it's known that it wouldn't work. In Mozilla forums some had tried to fix this by forcing Firefox to open in 32-bit mode (via Finder -> Applications -> right-click Firefox -> Get Info -> check Open in 32-bit mode), but I'd rather see the bug itself fixed.
    Apr 13, 2012 1:16 AM   in reply to AntD00d
    Hi All,
    Try running firefox in 32-bit mode as suggested by Juhanaven (via Finder -> Applications -> right-click Firefox -> Get Info -> check Open in 32-bit mode).
    However, Adobe has dropped support for all versions of Firefox prior to 10.0 for Acrobat/Reader 10.1.3 release. For more details see release notes
    Nikgupta
    Apr 13, 2012 8:04 AM   in reply to AntD00d
    Interesting. Where are you seeing this in Mozilla forums? I didn't see anyone talk about this Adobe Reader problem in Firefox newsgroups on news.mozilla.org news server even after I posted my issue.
    It's in this bug report: http://support.mozilla.org/fi/questions/925055 - confirmed already by 230 people, by the way...
    Sorry to hear that the 32-bit workaround didn't work for you. (I haven't even tested it yet myself, just disabled the plug-in altogether to get the pdf files even loaded to Preview...)
    Apr 13, 2012 8:13 AM   in reply to AntD00d
    Hi AntD00d,
    As I have mentinoed earlier Adobe has dropped support for all versions of Firefox prior to 10.0 for Acrobat/Reader 10.1.3 release ( For more details see release notes ).
    It would be great if you could upgrade to latest version of Firefox.
    Nikgupta
    Apr 13, 2012 8:25 AM   in reply to AntD00d
    I have the updated Firefox (10.0.3) and just updated Adobe reader to 10.1.3 - after the update, I can't open Adobe files in Firefox. I can open previously downloaded files fine, and can open new ones in Safari. I looked up the PDF plug-in for Firefox mentioned above, but that's for earlier versions of Firefox. So - should I just use Safari when there's a .pdf file until Adobe gets rid of the bug, or is there anything I can do?
    Apr 13, 2012 8:52 AM   in reply to 1NCGal65
    Hi 1NCGal65,
    Plese try opening PDF in firefox in 32-bit mode ( via Finder -> Applications -> right-click Firefox -> Get Info -> check Open in 32-bit mode).
    If it doesn't work please try the following steps:
    1. Delete the below mentioned files from the following location “/Library/Internet Plug-Ins/”
       1. AdobePDFViewer.plugin
       2. AdobePDFViewerNPAPI.plugin
    2. Once you have deleted the above files please download and reinstall Reader 10.1.3 from here.
    Also please mention your OS version.
    Nikhil
    Apr 13, 2012 9:02 AM   in reply to Nikhil.Gupta
    Thanks! Opening it in 32-bit mode worked! I appreciate the detailed instructions.   Oh, and it's Mac 10.7.3.
    Calculating status...
    Apr 14, 2012 5:03 PM   in reply to Nikhil.Gupta
    Nikhil,
    I'm sorry, but your answer doesn't make complete sense. I have the same issue - the new plugin just gives me a blank page and I am running Firefox 11 on OS X version 10.7.3. It isn't good enough for a release of the plugin to require users to run their software in 32-bit mode just to make it work - it's not as though Firefox is an obscure browser that no-one uses!
    When is there going to be a release to fix this?
    Apr 16, 2012 1:04 AM   in reply to AntD00d
    Hi AntD00d,
    As I suggested earlier did you try upgrading Firefox to latest version(10.0 or later).
    If it doesn't work even after upgrading Firefox to 10.0 or later then i suspect that there your pdfViewer plugin is corrupt.
    Then I recommend you to reinstall Reader and see if it works for you.
    However, before reinstalling please delete the below mentioned files from the following location “/Library/Internet Plug-Ins/”
    Nikhil Gupta
    Apr 21, 2012 4:56 AM   in reply to AntD00d
    You can also disable the Adobe NPAPI-Plugin in Firefox and use instead PDF Viewer-Addon (PDF.JS --> https://addons.mozilla.org/en-US/firefox/addon/pdfjs/),
    until they fix it for 64-Bit mode.
    In Firefox click on the menubar: Extras -> Add-ons. In the opened Addon-Tab you click "Plugins" on the left side and then deactivate "Adobe ... NPAPI ... 10.1.3"
    (the "Deactivate"-button is on the right side, if someone is searching and not viewing it. ).
    Install after the PDF Viewer-Addon by following above link. This addon works in 64-Bit mode.
    Apr 23, 2012 2:14 PM   in reply to juhanaven
    Nice that Mozilla actually has a way to report these issues to people who might notice. Is there any way to submit a bug to Adobe to the tune of "Reader doesn't work in 64-bit Firefox 12 on OS X" and actually have them listen? These forums sometimes feel like the elevators that have installed a non-working "Close Door" button just to placate you.
    Apr 30, 2012 5:43 AM   in reply to JustinTArthur
    Hi JustinTArthur
    You can use this form, provided by Adobe, to report bugs, request new features or suggest modifications to existing features.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    thanks,
    hit.anand
    Sep 24, 2012 11:42 AM   in reply to AntD00d
    Note that if you're running OSX in VMware, ALL NPAPI plugins are broken, not just Adobe Reader.
