BC is injecting an extra header into editted and re-uploaded pages.
The problem seems to disappear when I opt not to use a template.
A very strange problem with an even stranger fix! Is anybody else experiencing the same?
I should also mention that I was earlier locked out of the system (this one's a long story but is sort of ressolved now).
Hi Dave,
If you make a page with no template there is the basic html which is added into that page. If you click the HTML tag at the bottom of the editor you can see that. Then if you select a template it still has that HTML in the editor code which can cause probems.
If you find this to be the case you can go to the html tab for the editor of the page and remove that body/header html.
