css link href is not working in IE
Apr 12, 2012 4:46 AM
I have 2 links to external stylesheets and they work fine in chrome but running in IE it doesnt ref them
<link href="../SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
<link href="../css/font.css" rel="stylesheet" type="text/css" />
the reason they have the../ is because this if copied from the template
thanks
jon
    Apr 12, 2012 5:03 AM   in reply to Jonathan Fortis
    thanks
    jon
    This doesn't sound possible, if one browser is referencing the stylesheets correctly and they all should. If the link to the stylesheet was incorrect then no browser would show the styles.
    the ../ infront of the link indicates that the page which is referencing the css files is in another folder inside your site folder, is that correct?
    Maybe youre trying to view the template file itself and not a page made from the template?
    Apr 12, 2012 5:16 AM   in reply to Jonathan Fortis
    the stylesheets are in their own folder yes
    Where is the page though in relationship to your site folder?
    Apr 12, 2012 5:32 AM   in reply to Jonathan Fortis
    Can you upload this page anywhere so we can take a look and see where the problem is?
    if ../SpryAssets/SpryMenuBarHorizontal.css is working then the link is correct so it means if ../css/font.css is NOT working then the link is not correct to that file or there is something in that file which is stopping the css from working.
    Apr 12, 2012 5:50 AM   in reply to Jonathan Fortis
    Before I do anymore investigation can you close the gap between the 'u' and the 'tf' below which is at the top of your font.css style sheet and post back as let me know what happens.
    @charset "u tf-8";
    /* CSS Document */
    Apr 12, 2012 6:05 AM   in reply to Jonathan Fortis
    Add overflow: hidden; to the css selector below:
    #index-container #indexheader {
        background-image: url(images/header-nav-notext.jpg);
        height: 35px;
        padding-top: 245px;
        overflow: hidden;
    Youre not planing to use drop down menus are you? If so you cant use overflow: hidden;
    Apr 12, 2012 6:36 AM   in reply to Jonathan Fortis
    Move the css selector to the position as shown below and see what happens then.
    #index-container #indexcontent #indexcontentleft #latestCandidates {
        background-image: url(images/latestcandidates.jpg);
        height: 26px;
        width: 635px;
        padding-top: 10px;
        padding-right: 20px;
        padding-bottom: 15px;
        padding-left: 20px;
        margin-top: 5px;
        height: 35px;
        padding-top: 245px;
        overflow: hidden;
    </style>
    Apr 12, 2012 8:58 AM   in reply to Jonathan Fortis
    sorry, what page did that css come from?
    http://www.thinkfuturerecruitment.co.uk/beta/index.php
    What I'm saying is move the below to the very end of ALL the css and see if that resolves the issue.
    height: 35px;
    padding-top: 245px;
    overflow: hidden;
    Apr 12, 2012 9:20 AM   in reply to Jonathan Fortis
    On the index page you have the below at the moment right?
    height: 26px;
    width: 635px;
    padding-top: 10px;
    padding-left: 20px;
    margin-top: 5px;
    </style>
    <!-- InstanceEndEditable -->
    <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css" />
    <link href="css/font.css" rel="stylesheet" type="text/css" />
    Position the css as below (before the last closing </style> tag and before the links to your external css files.
    height: 26px;
    width: 635px;
    padding-top: 10px;
    padding-left: 20px;
    margin-top: 5px;
    height: 35px;
    padding-top: 245px;
    overflow: hidden;
    </style>
    I'm not sure IF this will solve the issue but when I tested it from this end it did.
    Apr 13, 2012 12:05 AM   in reply to Jonathan Fortis
    I tried putting that css in the index page uploaded it but it didnt give the css for the spry?
    Just moving the css selector to the end of the block of css would have no affect on the link to the spry. Can you insert itwhere I suggested then re-upload the page please. Then I'll take another look.
    Apr 13, 2012 3:20 AM   in reply to Jonathan Fortis
    i think i am getting confused....the
    height: 35px;
    padding-top: 245px;
    overflow: hidden;
    is only present on the index page, do i need to copy this onto all the pages??
    I'm only concerned about testing the index page first. If we can get it right on that page then it should be alright on the other pages.
    Obviously at the moment where the #index-container #indexheader css selctor is it doesn't work in IE so I'm asking you to move it to the end of your last css block on the index page.
    When I tested it there it did work in IE so I need to see if the same happens when you move it or whether we need to look for another solution.
    Apr 13, 2012 5:17 AM   in reply to Jonathan Fortis
    I think I've finally tracked this down. It seems you may have a corrupt .js file. Comment out <!--   --> as shown below:
    <!-- <script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script>-->
    If that does prove to be the case then this happens frequently with Spry js. In my opinion its the biggest bag of dog **** that was ever produced especaily where IE is concerned.
    If this solves the issue then unless you intend to use drop menus you don't need the js file.
