What's the difference between a Shape Layer and a Fill Layer anyway?
Apr 13, 2012 1:45 AM
I just realized that a Shape Layer is the same thing as a Fill Layer which has a Vector Mask.
Or that's how it looks anyway.
What's the difference?
    Apr 13, 2012 1:52 AM   in reply to John Stanowski
    The Shape Layer-setting usually results in a Solid Color Layer with a Vector Mask, but Fill Layers also include Pattern- and Gradient Layers.
    Apr 13, 2012 4:01 PM   in reply to John Stanowski
    This is correct, there is no difference, except the default names and the different steps of creation. The Shape layer is a Fill layer with a solid color and a vector mask. If you select a path from the Paths panel and choose  Layers > New Fill Layer > Solid Color, you get the same thing just not the same default name.
    Apr 13, 2012 5:15 PM   in reply to emil emil
    Iin CS5 and earlier, there isn't much difference because you only have a simple fill and a simple vector mask.
    In CS6 there is a more distinct difference, because the shape layer has 2 content generators (fill and stroke) and other properties that a simple vector mask does not have.
