Daily Crash/AutoRestart: Troubleshooting (CF9 on Ubuntu 11 on EC2 M1.Small)
Apr 13, 2012 2:05 AM
Tags: none (add) #server #coldfusion #coldfusion9 #cf9 #coldfusion_9Hello,
I have CF9 running on an Amazon M1.Small EC2 instance. The OS is Ubuntu 11. The instance has 1.7 GB memory and a single Xeon CPU.
Here is a tail of my /opt/coldfusion9/logs/cfserver.log (I've included the first 11 lines just to show that it appears nothing unusual was going on):
04/12 01:12:39 Information [jrpp-1079] - Starting HTTP request {URL='http://blog.[domain].com:80/mostrecent.php', method='post'}
04/12 01:12:39 Information [jrpp-1111] - HTTP request completed {Status Code=200 ,Time taken=11894 ms}
04/12 01:12:39 Information [jrpp-1187] - HTTP request completed {Status Code=200 ,Time taken=17524 ms}
04/12 01:12:39 Information [jrpp-1134] - HTTP request completed {Status Code=200 ,Time taken=11768 ms}
04/12 01:12:39 Information [jrpp-1134] - Starting HTTP request {URL='http://blog.[domain].com:80/mostrecent.php', method='post'}
04/12 01:12:39 Information [jrpp-1155] - HTTP request completed {Status Code=200 ,Time taken=12109 ms}
04/12 01:12:39 Information [jrpp-1155] - Starting HTTP request {URL='http://blog.[domain].com:80/mostrecent.php', method='post'}
04/12 01:12:39 Information [jrpp-1154] - HTTP request completed {Status Code=200 ,Time taken=12181 ms}
04/12 01:12:41 Information [jrpp-1199] - HTTP request completed {Status Code=200 ,Time taken=13582 ms}
04/12 01:12:42 Information [jrpp-1206] - HTTP request completed {Status Code=200 ,Time taken=14211 ms}
04/12 01:12:42 Information [jrpp-1122] - HTTP request completed {Status Code=200 ,Time taken=14669 ms}
And then, out of the blue I get a WebSitePulse alert and tail my log and it says it's restarting. Well, that's nice...hmmm.
autorestart: Restarting process
Starting Macromedia JRun 4.0 (Build 108858), coldfusion server
04/12 01:16:13 warning Unable to open /opt/coldfusion9/runtime/lib/license.properties
04/12 01:19:24 info JRun Naming Service listening on *:2932
04/12 01:22:35 error Connection refused to host: [external_ip]; nested exception is:
java.net.ConnectException: Connection timed out
[1]java.net.ConnectException: Connection timed out
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(Unknown Source)
at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(Unknown Source)
at sun.rmi.transport.tcp.TCPEndpoint.newSocket(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.createConnection(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.newConnection(Unknown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at jrun.servlet.session.SessionReplicationService_Stub.getRemoteServerNa me(Unknown Source)
at jrun.servlet.session.SessionReplicationService.start(SessionReplicati onService.java:53)
at jrun.servlet.ServletEngineService.createSessionReplicationService(Ser vletEngineService.java:130)
at jrun.servlet.ServletEngineService.start(ServletEngineService.java:112 )
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(Unknown Source)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(Unknown Source)
at com.sun.jmx.mbeanserver.PerInterface.invoke(Unknown Source)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(Unknown Source)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(Unknown Source)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(Unknown Source)
at jrunx.kernel.ServiceAdapter.invokeMethod(ServiceAdapter.java:705)
at jrunx.kernel.JRunServiceDeployer.invokeOnServices(JRunServiceDeployer .java:460)
at jrunx.kernel.JRunServiceDeployer.startServices(JRunServiceDeployer.ja va:312)
at jrunx.kernel.JRunServiceDeployer.startLifecycle(JRunServiceDeployer.j ava:260)
at jrunx.kernel.JRunServiceDeployer.deployServices(JRunServiceDeployer.j ava:87)
at jrunx.kernel.DeploymentService.loadServices(DeploymentService.java:46 )
at jrunx.kernel.JRun.startServer(JRun.java:575)
at jrunx.kernel.JRun.<init>(JRun.java:493)
at jrunx.kernel.JRun$1.run(JRun.java:346)
at java.security.AccessController.doPrivileged(Native Method)
at jrunx.kernel.JRun.start(JRun.java:343)
at jrunx.kernel.JRun.invoke(JRun.java:180)
at jrunx.kernel.JRun.main(JRun.java:168)
[0]java.rmi.ConnectException: Connection refused to host: [external_ip]; nested exception is:
Caused by: java.net.ConnectException: Connection timed out
... 47 more
04/12 01:22:36 info No JDBC data sources have been configured for this server (see jrun-resources.xml)
04/12 01:22:36 info JRun Proxy Server listening on *:51800
04/12 01:22:36 info Deploying enterprise application "Adobe_ColdFusion_9" from: file:/opt/coldfusion9/
04/12 01:22:37 info Deploying web application "Adobe ColdFusion 9" from: file:/opt/coldfusion9/
04/12 01:22:41 INFO License Service: Flex 1.5 CF Edition enabled
04/12 01:22:41 INFO Starting Flex 1.5 CF Edition
04/12 01:22:42 user JSPServlet: init
04/12 01:22:43 user ColdFusionStartUpServlet: init
04/12 01:22:43 user ColdFusionStartUpServlet: ColdFusion: Starting application services
04/12 01:22:43 user ColdFusionStartUpServlet: ColdFusion: VM version = 14.3-b01
04/12 01:22:44 Information [main] - Starting logging...
04/12 01:22:44 Information [main] - Starting license...
04/12 01:22:47 Information [main] - Standard Edition enabled
04/12 01:22:47 Information [main] - Starting crypto...
04/12 01:22:47 Information [main] - Starting security...
04/12 01:22:47 Information [main] - Starting scheduler...
04/12 01:22:48 Information [main] - Starting WatchService...
04/12 01:22:48 Information [main] - Starting debugging...
04/12 01:22:48 Information [main] - Starting sql...
04/12 01:22:48 Information [main] - Pool Manager Started
04/12 01:22:48 Information [main] - Starting mail...
04/12 01:22:48 Information [main] - Starting runtime...
04/12 01:22:48 Information [main] - CORBA Configuration not enabled
04/12 01:22:48 Information [main] - Starting cron...
04/12 01:22:49 Information [main] - Starting registry...
04/12 01:22:49 Information [main] - Starting client...
04/12 01:22:49 Information [main] - Starting xmlrpc...
04/12 01:22:49 Information [main] - Starting graphing...
04/12 01:22:49 Information [main] - Starting verity...
04/12 01:22:49 Information [main] - Starting solr...
04/12 01:22:49 Information [main] - Starting archive...
04/12 01:22:49 Information [main] - Starting document...
04/12 01:22:49 Information [main] - Starting eventgateway...
04/12 01:22:50 Information [main] - Starting Event Backend Handlers.
04/12 01:22:50 Information [main] - Initialized EventRequestDispatcher with a Thread Pool size of 1.
04/12 01:22:50 Information [main] - Initializing EventRequestHandler
04/12 01:22:50 Information [main] - Starting Event Gateways.
04/12 01:22:50 Information [main] - Starting FlexAssembler...
04/12 01:22:50 Information [main] - Starting .NET...
04/12 01:22:50 Information [main] - Starting Monitoring...
04/12 01:22:51 Information [main] - ColdFusion started
04/12 01:22:51 user ColdFusionStartUpServlet: ColdFusion: application services are now available
04/12 01:22:51 user CFMxmlServlet: init
04/12 01:22:51 user CFMxmlServlet: Macromedia Flex Build: 87315.134646
04/12 01:22:51 INFO Macromedia Flex Build: 87315.134646
04/12 01:22:56 user CFSwfServlet: init
04/12 01:22:56 user CFCServlet: init
04/12 01:22:56 error There is no web application configured to service your request
04/12 01:22:56 user NoWebappServlet: init
04/12 01:22:59 user FlashGateway: init
04/12 01:23:00 user MessageBrokerServlet: init
04/12 01:23:00 user CFFormGateway: init
04/12 01:23:01 user CFInternalServlet: init
04/12 01:23:01 user WSRPProducer: init
04/12 01:23:02 user ServerCFCServlet: init
Server coldfusion ready (startup time: 602 seconds)
602 Seconds? That's um... 10 minutes to startup, and since I'm monitoring the server at 15 minute intervals, it logs 15 minutes of estimated downtime for my client's displeasure.
In the meantime (prior to the restart having completed), the server's handing out Error 500's like this:
Server Error
The server encountered an internal error and was unable to complete your request.
Could not connect to JRun Server.
So, I check /opt/coldfusion9/bin/coldfusion status and it tells me:
Could not contact the ColdFusion Application Server running on this machine:
Perhaps ColdFusion is not running on this machine?
Perhaps cfstat is not enabled from the ColdFusion administrator?
Perhaps ColdFusion was not restarted after enabling cfstat?
Perhaps cfstat service is not listening on default port?
Use option -port with port number as per the cfstatport
defined in the neo-metrics xml file.
Erm. Funny that that status script could contact the CAS because when I ran `top`, I could see it using up CPU and RAM, and a `ps aux` revealed it was, in fact, running...maybe it was just still starting up and wasn't ready to "talk". I'm not sure.
Obviously, I'm curious as to what the cause was in the first place...cfserver.log just before the `autorestart` isn't telling me much, so I tail the application.log and the exception log but there's nothing in there with a timestamp right before this mysterious autorestart.
This is weird too: I can't actually seem to stop the CF server from running:
root@coffeereview:~# /opt/coldfusion9/bin/coldfusion status
Pg/Sec DB/Sec CP/Sec Reqs Reqs Reqs AvgQ AvgReq AvgDB Bytes Bytes
Now Hi Now Hi Now Hi Q'ed Run'g TO'ed Time Time Time In/Sec Out/Sec
0 0 0 0 -1 -1 0 0 0 0 -46102960 0 0
root@coffeereview:~# /opt/coldfusion9/bin/coldfusion stop
Stopping ColdFusion 9, please wait
Stopping coldfusion server............................................................... ................................^C
Here, I get tired of waiting and hit Ctrl-C, but sometimes I'll wait and wait and it never does anything other than draw dots.
0 0 0 0 -1 -1 0 0 0 0 -11525740 0 0
Still running. Obviously, I could hit the PID with a kill -9, but that seems a lottle rough, and not the ideal way to go about it. Last time I force quit it that way, I think it took even longer than 10 minutes to start back up when I ran `service coldfusion9 start`.
So, my goal here is to figure out these 3 things:
1. Why is my CF server is crashing and restarting?
2. Why does it take so long to restart? and
3. Why can I not stop the CF server by normal means?
Any help with answering these questions would be much appreciated.
