Hit Test Object..
Apr 13, 2012 Apr 13, 2012
Hi ii want my character to walk down the screen and hit the objectWall and then a movieclip then gets added to the stage and plays but it doesnt seem to work and ii dont know why.
import flash.display.MovieClip;
import flash.ui.Keyboard;
import flash.events.Event;
stop();
//1. Set booleans for the status of the arrow presses
var downArrow:Boolean = false;
//2. Add event listeners for the keys
stage.addEventListener(KeyboardEvent.KEY_UP, nokeyHit);
stage.addEventListener(KeyboardEvent.KEY_DOWN, keyHit);
stage.addEventListener(Event.ENTER_FRAME, moveObject);
//3. Function to detect if a key has been hit
function keyHit(event:KeyboardEvent):void
          switch (event.keyCode)
                    case Keyboard.DOWN :
                              downArrow = true;
                              break;
//4. Function to detect if a key has not been hit
function nokeyHit(event:KeyboardEvent):void
                              downArrow = false;
                              break;
//5. Function to move the object
function moveObject(event:Event):void
          var speed:Number = 2;
          if (downArrow)
                    objectMove.y +=  speed;
          hitWalls();
//6. Function to test hitting the walls
function hitWalls():void
          var left:Number = 0;
          var right:Number = stage.stageWidth;
          var top:Number = 0;
          var bottom:Number = stage.stageHeight;
          if (objectMove.x  - (objectMove.width / 2) > right)
                    objectMove.x = left - objectMove.width / 2;
          else if (objectMove.x + objectMove.width / 2 < left)
                    objectMove.x = right + objectMove.width / 2;
          if (objectMove.y + (objectMove.height / 2) > bottom)
                    objectMove.y = bottom - (objectMove.height / 2);
          else if (objectMove.y - (objectMove.height / 2) < top)
                    objectMove.y = top + (objectMove.height / 2);
objectMove.addEventListener(Event.ENTER_FRAME, testHit);
function testHit(event:Event):void
          var Attack:MovieClip = new MovieClip;
          if (objectMove.hitTestObject(objectWall))
                    objectMove.removeEventListener(Event.ENTER_FRAME, testHit);
                    addChild(Attack);
Any Help Would Be Great Thanks.
ActionScript
689
LEGEND , Apr 13, 2012 Apr 13, 2012
The problem is in this line...
You are just adding a MovieClip object.  It will be an invisible thing because it contains nothing.  If you happen to have some other object that you have assigned a class name, maybe like AttackMC that sits in the library waiting to be added, you would use...
var Attack:AttackMC = new AttackMC();
Nore: It is standard practice to only use Capitalized names for classes, not variables... it just helps someone else understand your
Nore: It is standard practice to only use Capitalized names for classes, not variables... it just helps someone else understand your code easier.
