Hi ii want my character to walk down the screen and hit the objectWall and then a movieclip then gets added to the stage and plays but it doesnt seem to work and ii dont know why.
import flash.display.MovieClip;
import flash.ui.Keyboard;
import flash.events.Event;
stop();
//1. Set booleans for the status of the arrow presses
var downArrow:Boolean = false;
//2. Add event listeners for the keys
stage.addEventListener(KeyboardEvent.KEY_UP, nokeyHit);
stage.addEventListener(KeyboardEvent.KEY_DOWN, keyHit);
stage.addEventListener(Event.ENTER_FRAME, moveObject);
//3. Function to detect if a key has been hit
function keyHit(event:KeyboardEvent):void
switch (event.keyCode)
case Keyboard.DOWN :
downArrow = true;
break;
//4. Function to detect if a key has not been hit
function nokeyHit(event:KeyboardEvent):void
downArrow = false;
break;
//5. Function to move the object
function moveObject(event:Event):void
var speed:Number = 2;
if (downArrow)
objectMove.y += speed;
hitWalls();
//6. Function to test hitting the walls
function hitWalls():void
var left:Number = 0;
var right:Number = stage.stageWidth;
var top:Number = 0;
var bottom:Number = stage.stageHeight;
if (objectMove.x - (objectMove.width / 2) > right)
objectMove.x = left - objectMove.width / 2;
else if (objectMove.x + objectMove.width / 2 < left)
objectMove.x = right + objectMove.width / 2;
if (objectMove.y + (objectMove.height / 2) > bottom)
objectMove.y = bottom - (objectMove.height / 2);
else if (objectMove.y - (objectMove.height / 2) < top)
objectMove.y = top + (objectMove.height / 2);
objectMove.addEventListener(Event.ENTER_FRAME, testHit);
function testHit(event:Event):void
var Attack:MovieClip = new MovieClip;
if (objectMove.hitTestObject(objectWall))
objectMove.removeEventListener(Event.ENTER_FRAME, testHit);
addChild(Attack);
Any Help Would Be Great Thanks.
The problem is in this line...
You are just adding a MovieClip object. It will be an invisible thing because it contains nothing. If you happen to have some other object that you have assigned a class name, maybe like AttackMC that sits in the library waiting to be added, you would use...
var Attack:AttackMC = new AttackMC();
Nore: It is standard practice to only use Capitalized names for classes, not variables... it just helps someone else understand your
...Copy link to clipboard
Nore: It is standard practice to only use Capitalized names for classes, not variables... it just helps someone else understand your code easier.
