A.kameshwaran
Movieclip Sort
Apr 12, 2012 11:59 PM
Hi
I am having set of movieclips, say
mc1,mc2,mc3,mc4 and mc5
I do have the properties for these movieclips as below
mc1.val = 4
mc2.val = 7
mc3.val = 3
mc4.val = 2
mc5.val = 7
I need to know how can i sort these movieclips in ascending order like below based on the variable val .
mc4 , mc3 , mc1 , mc2 , mc5
Kameshwaran A.
    Apr 13, 2012 5:02 AM   in reply to A.kameshwaran
    What kind of set are they contained in such that you would have reason to sort them?
    Apr 13, 2012 6:23 AM   in reply to A.kameshwaran
    What you can do is place them into an array as objects, each defining the mc and its val property, and then use the Array.sortOn method...
    mc1.val = 4;
    mc2.val = 7;
    mc3.val = 3;
    mc4.val = 2;
    mc5.val = 7;
    var mcs:Array = new Array({mc:mc1, val:mc1.val},{mc:mc2, val:mc2.val},{mc:mc3, val:mc3.val},{mc:mc4, val:mc4.val},{mc:mc5, val:mc5.val});
    var sortedMCs:Array = mcs.sortOn("val", Array.NUMERIC);
    for(i=0;i<sortedMCs.length;i++){
        trace(sortedMCs[i].mc)
    Apr 16, 2012 4:33 AM   in reply to A.kameshwaran
    The code you show is working, though you might be misreading the results due to the way they resemble the order of the values you started with.  You are tracing the mcs, not the val properties
    The original array has them ordered mc1 2 3 4 5, while the sorted one has 3 2 1 4 5
    Apr 16, 2012 6:17 AM   in reply to A.kameshwaran
    You're welcome
