Is it possible to forced Closed Captions to turn on by default in Captivate 5.5?
Apr 12, 2012 10:22 AM
Tags: #captivate #5.5 #advanced #actions #5 #captions #closed #captioning
I am creating an eLearning course with Spanish subtitles. I have the Closed Captioning button enabled in my Skin Editor, but I would like it if the user did not have to click the CC button to turn closed captions on. Is there a way to accomplish this with advanced actions? Thanks so much.
    Apr 12, 2012 10:28 AM   in reply to avary.s
    Hello,
    There is a system variable cpCmndCC, if you assign the value 1 CC will be shown. You can create a short advanced action to be triggered on entering the first slide with those statements:
         Assign cpCmndCC
          Continue
    However, to be safe, it is better to insert a very short first slide and execute this action on entering the second slide to give CP the time to trigger it.
    Lilybiri
    Apr 12, 2012 8:13 PM   in reply to avary.s
    The synchronisation issue is likely because Captivate was still getting things sorted out at runtime by the time you had specified the voiceover audio should start.
    It's generally regarded as good practice to NOT put voiceover that requires synchronisation on the very first slide.  I usually have an initial blank slide of a second or two duration to allow Captivate to get set, then I have a title slide with a little intro music that goes for about 7-9 seconds where I display info about the name of the course, department, module, duration etc.  Then on the third slide I start my voiceover and CC text.  This seems to work well and the users are getting all the info they need without synchronisation issues.
    Apr 13, 2012 6:21 AM   in reply to avary.s
    Is there any audio (e.g. an intro music clip) on the slides before your CC slide?  Try adding a short piece of music (no issue with synching CC) and see if that helps.  Perhaps the synch issue will only crop up on the first slide to have audio at all.  But if that slide is just music, your users will be none the wiser.
    Captivate comes with a small number of intro clips in the Gallery > Sounds folder.  Try the Loop Acoustic Mellow MP3 clip.
