Strange error that occurs randomly...
Apr 2, 2012 5:41 AM
Tags: #flash_builder #flex #actionscript #flash_builder_4.5 #flex4.5
HI,
I'm using flash builder and I have a strange error, this error occurs randomly and in order to fix it I do the following:
1) Remove the line where the error is
2) Save the file (so the workspace is rebuild), the problem is gone
3) Paste the line removed
4) Save again and there is no problem
Here's a piece of code:
protected function comboHandler(event:ComboEvent):void
          u.profilo = Profilo(event.picked);
The ComboEvent picked is of type Object
The u is referring to a class where there is a getter and setter
public function get profilo():Profilo
          return profilo_value;
public function set profilo(i:Profilo):void
          profilo_value = i;
The error I get from Flash Builder is
1118: Implicit coercion of a value with static type listClass:Profilo to a possibly unrelated type listClass:Profilo.
Why do I get this error?
Is it related to flash builder?
    Apr 13, 2012 6:00 AM   in reply to Z4g0s
    It would be great if you share code snippets of the Profilo class?
    Apr 13, 2012 6:33 AM   in reply to Z4g0s
    Its gives error in this line :
    Its error related to type conversion. Refer the following example:
    Application file:
    <?xml version="1.0" encoding="utf-8"?>
    <!-- http://bharatria.wordpress.com/ -->
    <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                                     xmlns:s="library://ns.adobe.com/flex/spark"
                                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
              <fx:Script>
                        <![CDATA[
                                  import spark.events.IndexChangeEvent;
                                  import testClass.Profilo;
                                  protected function cb_changeHandler(event:IndexChangeEvent):void
                                                 // TODO Auto-generated method stub
                                                 var classRef:Profilo = new Profilo();
                                                 classRef.profilo = String(cb.selectedItem);
              </fx:Script>
              <s:ComboBox id="cb"
                                            change="cb_changeHandler(event)">
                        <s:ArrayList>
                                  <fx:String>Flash</fx:String>
                                  <fx:String>Flex</fx:String>
                                  <fx:String>Dreamweaver</fx:String>
                                  <fx:String>Photoshop</fx:String>
                        </s:ArrayList>
              </s:ComboBox>
    </s:Application>
    Profilo Class :
    package testClass
              import mx.collections.ArrayList;
              public class Profilo
                        public var profilo_value:String = "";
                        public function get profilo():String
                        public function set profilo(i:String):void
                                  profilo_value = i;
