I have used the login behavior in dreamweaver and when i run the page it give the following error
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /usr/users1/jonfort/public_html/think/beta/index.php:263) in/usr/users1/jonfort/public_html/think/beta/index.phpon line 474
i have looked at the error line session_start();
the rouble is the form is in a template and used across the whole site. i have placed the php in the body of the page so it will carry across all the pages and the error is pointing to the line that is locked
has anyone else had this problem and how do you overcome it
thanks in advance
i tryed putting the code at the start of one of the pages and got the following error
Fatal error: Call to undefined function: getsqlvaluestring() in /usr/users1/jonfort/public_html/think/beta/index.php on line 23
the code is
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
This says that you have already had an output which started on line 263.
If you have a look here http://forums.adobe.com/message/4332163#4332163 you will see that I placed the session_id and session_start at the very top of the page when no output has occurred.
session_start() must be repeated on each page that requires the session variables.
Gramps
i placed this whole code at the top of the page
<?php
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['userid'])) {
$loginUsername=$_POST['userid'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "php.php";
$MM_redirectLoginFailed = "failed.php";
$MM_redirecttoReferrer = false;
mysql_select_db($database_hostprop, $hostprop);
$LoginRS__query=sprintf("SELECT userid, password FROM think_signup WHERE userid=%s AND password=%s",
$LoginRS = mysql_query($LoginRS__query, $hostprop) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && false) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
and it returned the error
The problem is not with the data. Quite simply the function is not defined. DW usually puts some code like:
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
Up at the top of the PHP file and that is missing from yours.
