I can't install Adobe AIR. I'm getting the infamous error:
"An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator."
Here is my install log:
[2012-04-13:11:31:20] Runtime Installer begin with version 3.2.0.2070 on Windows 7 x86
[2012-04-13:11:31:20] Commandline is:
[2012-04-13:11:31:20] No installed runtime detected
[2012-04-13:11:31:42] Relaunching with elevation
[2012-04-13:11:31:42] Launching subprocess with commandline c:\users\mmazza\appdata\local\temp\aira62d.tmp\adobe air installer.exe -ei
[2012-04-13:11:31:42] Runtime Installer begin with version 3.2.0.2070 on Windows 7 x86
[2012-04-13:11:31:42] Commandline is: -stdio \\.\pipe\AIR_5604_0 -ei
[2012-04-13:11:31:42] No installed runtime detected
[2012-04-13:11:31:43] Starting silent runtime install. Installing runtime version 3.2.0.2070
[2012-04-13:11:31:43] Installing msi at c:\users\mmazza\appdata\local\temp\aira62d.tmp\setup.msi with guid {47FA2C44-D148-4DBC-AF60-B91934AA4842}
[2012-04-13:11:31:45] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-04-13:11:31:45] Rolling back install of c:\users\mmazza\appdata\local\temp\aira62d.tmp\setup.msi
[2012-04-13:11:31:45] Rollback complete
[2012-04-13:11:31:45] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-04-13:11:31:45] Runtime Installer end with exit code 7
[2012-04-13:11:31:47] Runtime Installer end with exit code 7
Hope someone can help. Thanks.
Unfortunately, the error is in the MSI portion of the installer. This requires another log file to see what's going on. Usually the Microsoft fix it takes care of this for us, but as you mentioned if AIR isn't in the list it's not very helpful. Hopefully viewing the log will show us what's wrong and we can fix it.
Chris, thanks for your help. Here's the log:
=== Logging started: 4/16/2012 11:16:05 ===
Action start 11:16:05: INSTALL.
Action start 11:16:05: FindRelatedProducts.
Action ended 11:16:05: FindRelatedProducts. Return value 1.
Action start 11:16:05: ValidateProductID.
Action ended 11:16:05: ValidateProductID. Return value 1.
Action start 11:16:05: SetSHAREDADDINFOLDER.
Action ended 11:16:05: SetSHAREDADDINFOLDER. Return value 1.
Action start 11:16:05: CostInitialize.
Action ended 11:16:05: CostInitialize. Return value 1.
Action start 11:16:05: FileCost.
Action ended 11:16:05: FileCost. Return value 1.
Action start 11:16:05: CostFinalize.
Action ended 11:16:06: CostFinalize. Return value 1.
Action start 11:16:06: MigrateFeatureStates.
Action ended 11:16:06: MigrateFeatureStates. Return value 0.
Action start 11:16:06: InstallValidate.
Action ended 11:16:06: InstallValidate. Return value 1.
Action start 11:16:06: SetARPINSTALLLOCATION.
Action ended 11:16:06: SetARPINSTALLLOCATION. Return value 1.
Action start 11:16:06: InstallInitialize.
Action ended 11:16:07: InstallInitialize. Return value 1.
Action start 11:16:07: ProcessComponents.
Action ended 11:16:07: ProcessComponents. Return value 1.
Action start 11:16:07: UnpublishFeatures.
Action ended 11:16:07: UnpublishFeatures. Return value 1.
Action start 11:16:07: RemoveRegistryValues.
Action ended 11:16:07: RemoveRegistryValues. Return value 1.
Action start 11:16:07: RemoveDuplicateFiles.
Action ended 11:16:07: RemoveDuplicateFiles. Return value 1.
Action start 11:16:07: RemoveFiles.
Action ended 11:16:07: RemoveFiles. Return value 0.
Action start 11:16:07: InstallFiles.
Action ended 11:16:07: InstallFiles. Return value 1.
Action start 11:16:07: DuplicateFiles.
Action ended 11:16:07: DuplicateFiles. Return value 1.
Action start 11:16:07: WriteRegistryValues.
Action ended 11:16:07: WriteRegistryValues. Return value 1.
Action start 11:16:07: RegisterUser.
Action ended 11:16:07: RegisterUser. Return value 1.
Action start 11:16:07: RegisterProduct.
Action ended 11:16:07: RegisterProduct. Return value 1.
Action start 11:16:07: PublishFeatures.
Action ended 11:16:07: PublishFeatures. Return value 1.
Action start 11:16:07: PublishProduct.
Action ended 11:16:07: PublishProduct. Return value 1.
Action start 11:16:07: InstallExecute.
MSI (s) (EC:04) [11:16:09:069]: Product: Adobe AIR -- Error 1402. Could not open key: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.air\OpenWithProgids. System error 5. Verify that you have sufficient access to that key, or contact your support personnel.
Action ended 11:16:09: InstallExecute. Return value 3.
Action ended 11:16:10: INSTALL. Return value 3.
Property(S): ARPINSTALLLOCATION = c:\Program Files\Common Files\Adobe AIR\
Property(S): SHAREDADDINFOLDER = c:\Program Files\Adobe\Flash Player\AddIns\airappinstaller\
Property(S): UpgradeCode = {8DA920D5-C41C-42E0-BF31-87BA49984EE4}
Property(S): UC8DA920D5C41C42E0BF3187BA49984EE4 = {FDB3B167-F4FA-461D-976F-286304A57B2A}
Property(S): Resources = c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\
Property(S): Version = c:\Program Files\Common Files\Adobe AIR\Versions\1.0\
Property(S): Versions = c:\Program Files\Common Files\Adobe AIR\Versions\
Property(S): AIR = c:\Program Files\Common Files\Adobe AIR\
Property(S): CommonFilesFolder = c:\Program Files\Common Files\
Property(S): TARGETDIR = c:\
Property(S): SourceDir = c:\users\mmazza\appdata\local\temp\air5438.tmp\
Property(S): Manufacturer = Adobe Systems Incorporated
Property(S): ProductCode = {47FA2C44-D148-4DBC-AF60-B91934AA4842}
Property(S): ProductLanguage = 1033
Property(S): ProductName = Adobe AIR
Property(S): ProductVersion = 3.2.0.2070
Property(S): REINSTALLMODE = amus
Property(S): ARPSYSTEMCOMPONENT = yes
Property(S): REBOOT = Suppress
Property(S): ALLUSERS = 1
Property(S): SecureCustomProperties = ARPSYSTEMCOMPONENT;REINSTALLMODE;SHAREDADDINFOLDER;UC8DA920D5C41C42E0 BF3187BA49984EE4
Property(S): MsiLogFileLocation = C:\Users\mmazza\AppData\Local\Temp\MSI46b03.LOG
Property(S): PackageCode = {496CC99A-E905-4C30-B3F0-14CB137CACAC}
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): CURRENTDIRECTORY = C:\Users\mmazza\Downloads
Property(S): CLIENTUILEVEL = 3
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTPROCESSID = 1156
Property(S): VersionDatabase = 200
Property(S): VersionMsi = 5.00
Property(S): VersionNT = 601
Property(S): WindowsBuild = 7600
Property(S): ServicePackLevel = 0
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): WindowsFolder = c:\Windows\
Property(S): WindowsVolume = c:\
Property(S): SystemFolder = C:\Windows\system32\
Property(S): System16Folder = C:\Windows\system\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\Users\mmazza\AppData\Local\Temp\
Property(S): ProgramFilesFolder = C:\Program Files\
Property(S): AppDataFolder = C:\Users\mmazza\AppData\Roaming\
Property(S): FavoritesFolder = C:\Users\mmazza\Favorites\
Property(S): NetHoodFolder = C:\Users\mmazza\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): PersonalFolder = C:\Users\mmazza\Documents\
Property(S): PrintHoodFolder = C:\Users\mmazza\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): RecentFolder = C:\Users\mmazza\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SendToFolder = C:\Users\mmazza\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): LocalAppDataFolder = C:\Users\mmazza\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\mmazza\Pictures\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): Intel = 6
Property(S): PhysicalMemory = 3325
Property(S): VirtualMemory = 4304
Property(S): AdminUser = 1
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = mmazza
Property(S): UserSID = S-1-5-21-823518204-1563985344-842925246-12804
Property(S): UserLanguageID = 1033
Property(S): ComputerName = RGPROWS1015
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 11:16:10
Property(S): Date = 4/16/2012
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): RedirectedDllSupport = 2
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): USERNAME = d
Property(S): DATABASE = c:\Windows\Installer\446fe3.msi
Property(S): OriginalDatabase = c:\users\mmazza\appdata\local\temp\air5438.tmp\setup.msi
Property(S): UILevel = 2
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = c:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): INSTALLLEVEL = 1
Property(S): SOURCEDIR = c:\users\mmazza\appdata\local\temp\air5438.tmp\
Property(S): SourcedirProduct = {47FA2C44-D148-4DBC-AF60-B91934AA4842}
Property(S): ProductToBeRegistered = 1
MSI (s) (EC:04) [11:16:10:707]: Product: Adobe AIR -- Installation failed.
MSI (s) (EC:04) [11:16:10:720]: Windows Installer installed the product. Product Name: Adobe AIR. Product Version: 3.2.0.2070. Product Language: 1033. Manufacturer: Adobe Systems Incorporated. Installation success or error status: 1603.
=== Logging stopped: 4/16/2012 11:16:10 ===
I've tried to delete the HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.air\OpenWithProgids key, but I got the message "Cannot delete. Error while deleting key"
Hi Chris, thanks for the advice.
I've tried to delete HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.air and I can't. I get this error:
Cannot delete .air: Error while deleting key.
I gave my user permissions (Full Control) to this key and it dind't work.
When I try to open HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.air\OpenWithProgids, I get the following error:
OpenWithProgids cannot be opened.
An error is preventing this key from being opened.
Details: Access is denied.
When I try to give permissions I get this:
Unable to save permission changes on OpenWithProgids.
Accesss is denied.
I've tried CCleaner, regDALC and RegDelNull to delete the key, and nothing works. ![]()
