Is there a way to maximize the crop box?
Apr 13, 2012 6:20 AM
Tags: #cs6_beta #crop_tool
Terms: I consider a crop box maximized when it is as large as it can be without exceeding the image size in either dimension.  (For an unconstrained crop, a maximized crop box contains the entire image.)
When I first select the new crop tool, it is maximized.  If I change the crop box, the only ways I have found to get it maximized again are to cancel the crop and restart -- or zoom in to the pixel level and adjust the crop boundaries.
Am I missing some magic incantation?
(This 'maximize crop' feature is one we have -- and use -- in some other image processing software.)
    Apr 13, 2012 6:24 AM   in reply to OC Photoworx
    It seems like you are correct. If you previous set something other than "Unconstrained", the Crop Tool remembers your last setting. Using the Reset Crop button (top right of Options Bar) will maximize the crop area to your current image.
    Apr 13, 2012 7:19 AM   in reply to OC Photoworx
    And the first choice in the right+click (control+click) menu is reset crop.
    Apr 13, 2012 9:17 AM   in reply to OC Photoworx
    I set the crop box to 13in by 19in then open a landscape image.  It opens with the crop box in place, giving me a portrait crop out of the middle of the image.  I rotate the image using the mouse and delayed shift key so it's in portrait orientation.  The crop box is giving me the middle of the image (not the whole thing).  Fit on screen lets me see the entire image but obviously doesn't alter the crop area.
    I don't understand your workflow... but I think I see what you mean.
    When you are rotating the image, the crop marquee resizes to be as large as possible in the image area, until you go past 45º... then it stays the same size. And you are wanting it to keep resizing as large as possible?
    If you just hit the X key after the first step (rotating the crop box, not the image) does that help?
    Apr 13, 2012 11:21 AM   in reply to OC Photoworx
    You might try Ctrl (cmd)+Z or commit the crop and then undo.
    Apr 13, 2012 1:59 PM   in reply to OC Photoworx
    To me, that escalates this to a legitimate bug.
    Well... maybe.
    But back to your example and my suggestion: If you have a "portrait" oriented Crop setting and open a "landscape" oriented image, doesn't just hitting the X key to swap the crop ratio make the Crop Tool behave like you want it to?
