Jump to Slide glitches
Apr 13, 2012 9:10 AM
Just wondering if anyone has found an effect solution to the glitches with Jump to Slide. I've tried two different methods in a jeopardy game project. I have done Jump to slide as part of an advanced action and when I found that some would work but not all...I added slides after question slides that would do a Jump to slide "on enter" which reduced the problem...but I still get problems where it just won't jump to slide, period.
    Apr 13, 2012 9:20 AM   in reply to RiskLMSspecialist
    Mostly those 'glitches' are caused by scored objects and bumping into the quiz scope, and by quiz preferences.  Really, I didn't experience those issues up till now... always found an explanation.
    Lilybiri
    Apr 13, 2012 6:16 PM   in reply to RiskLMSspecialist
    True/False questions should not cause such issues.  Were these projects originally created from scratch in the version of Captivate that you're using now, or were they created in an earlier version and then upgraded.  If the latter, try removing any questions created in earlier versions and recreating them again from scratch in the current version.  I've sometimes found that upgraded questions gave issues and you needed to ensure all questions matched the current Cp version.
    Apr 14, 2012 3:36 AM   in reply to RiskLMSspecialist
    Interesting.  Oh well, I guess you can still use multiple choice questions with only two answers to simulate True/False questions anyway.
    Apr 16, 2012 7:38 AM   in reply to RiskLMSspecialist
    just a guess.  did you have 'continue' at the end of your advanced actions?  not having it may cause problems like you're describing.
