In Acrobat 8 Pro, Place Mulitple Fields had the expected effect of correctly incrementing a calculated field downward so the calculations for a line were incremented to match the line, .0, .1, .2 etc. This functionality was BROKEN in version 9 Pro so that the calculated fields merely duplicated the first line reference with a .0 appended; 30 calculated lines, 30 identical field references. I was told by customer support "that's how it works." I emphasized that was NOT how it worked in version 8. No promise to fix it, naturally. I hoped it would be fixed when I upgraded from CS3 to CS4. Nope, same broken version of Acrobat 9 between those two versions. Here we are at CS5.5 and Acrobat X Pro is STILL broken in this regard. My only question now is, "Will CS6 use the same version of Acrobat X Pro, or will there be a new broken version?"
George
Forms are here
https://www.dropbox.com/sh/z3xhhkrw3z3tyg6/js8ufWUgVF
I know nothing about Javascript.
Jonathan
In this case you can also use the simplified field notation, though it would be much easier if you were to change your field names. For example, the first row you want to sum the following two fields:
"REG. HRS" and "O.T. HRS"
Since the field names include the period and space characters these need to be escaped, so you'd have to enter the following:
REG\.\ HRS + O\.T\.\ HRS
If you were to change the names to:
"REG_HRS" and "OT_HRS"
The simplified field notation entry would be simply:
REG_HRS + OT_HRS
If you were to further refine the field naming scheme to something like:
Row 1: R1.REG_HRS, R1.OT_HRS
Row 2: R2.REG_HRS, R2.OT_HRS
A single script could be used for all of the rows, and called in the calculate event of each "DAILY TOTAL" field. I realize this may sound like jibberish at the moment, but if you want to pursue it, post again. In the mean time, the simplified field notation option will work.
See How to use basic calculations in PDF forms by Donna Baker.
You field names can not contain spaces or dots in their names or you will need to use the special "escape" character to have the JavaScript behind the Simplified field notation accept the non-standard or special character.
I was told by Adobe Technical Support I would have to go into each row total (your example Row1Total.0 through .x after the Place Multiple Fields) and change the references to the appropriate line. Then your Col5 total would be accurate. To me this was Technical Support's way of saying, "Yes, it worked in version 8, but now you have to do it manually— and we're not going to fix it." If it could be handled by a JS, as some have implied, why not just (re)build it into the application? I don't know the answer to that, and Technical Support isn't saying.
