I have created some forms that have multiple layers in them. They are several pages long. On page 1 there are 3 radio buttons . . . the user selects their appropriate user type and that turns on the correct layer and turns off the other layers. Unfortunately, if they go to page 2 before clicking one of the butttons, they see all of the layers at once, and it's a jumbled mess.
Is there a way to set the default layer visibility so that when you open the PDF, it shows only the layer I want it to? I can't find this in the initial view settings.
Thanks in advance for any help provided!
Yes, you can use a document level script to set the state of the OCG, Optonal Content Group or layer, objects intial states.
var nOCG = 0; // number of OCG to display
// set all OCGs off
var ocgs = this.getOCGs();
ocgs[0].initState.constants.states.off;
// turnon the one OCG for initial view
ocgs[nOCG].initState.constants.states.on;
I'm finally getting around to using the script you so generously provided. Client sat on the project for months, and now they want it fixed.
I have 4 layers, or OCGs (sounds like that is what javascript calls them), named "Common", "Staff", "Supervisor", and "Manager" - and I would like the intial view to show the layers "Common" and "Staff" . . . how would I plug that into the script above?
Does javascript refer to the OCGs by name, or do they have numbers associated with them?
Here is my attempt - but really just a guess, and it did not work:
function InitialLayerView()
var nOCG = 1; // number of OCG to display
var nOCG2 = 2; // number of OCG to display
// set all OCGs off
// turnon the two OCGs for initial view
ocgs[nOCG2].initState.constants.states.on;
Also - once I close the script, save and reopen the file, should I have to do anything to run the script? I'm hoping it just runs on open.
Thanks for any help you can give!
