Grep style - add brackets around number
Apr 12, 2012 10:33 AM
Tags: #toc #indesign #grep
Hi there,
I am wondering if there is a way to use GREP styles to apply brackets around a number. I am looking for it to be a grep style (within the paragraph style) and not a find and replace.
This will be used in an automated table of contents where the page number will be in brackets. (Is this something I can specify in TOC settings?)
Like such:
Contents
Chapter One     [3]
Chapter Two     [10]
Chapter Three  [15]
Again, it needs to be part of the paragraph style (or TOC settigns) so the brackets are automatically applied to numbers when the associated paragraph style is used.
Hope someone can help me out!
    Apr 12, 2012 4:59 PM   in reply to wbset09
    GREP styles cannot add glyphs. While you can add the braracket before the number in the TOD settings, there is no way I know to add it after other than find/change or possibly a script.
    Apr 13, 2012 2:46 AM   in reply to Peter Spier
    Try this:-
    Go to Edit-->Table of Cotents
    in the Tabke of Content dialog box , click on "more options" to have the complete options (by default some are hidden)
    In the Table of Content dialog box , look for "Between Entry and Number" , there would be text "^t" (basically this is the tab character) , after this type "[" , so the
    complete text in "Between Entry and Number" will look like "^t["
    Then Update your table of content , and every entry in your table of content will have the "[" infront of it....now it will much easire to run "GREP"
    Go to Edit-->Find/change
    go to GREP tab
    In "Find what" put:-  \[\d+
    In "Change to" :- $0]
    now , click on the "find next' to see the entry of the Table of content and "Change' to change the entry to like [3], [4] etc
    Drawback of this workflow:--  Every entry in the document will be serached not only the TOC hence if incase your document has entry of kind :- [356 , [34 , they will be searched and changed so be cautious for that
    Apr 13, 2012 4:24 AM   in reply to Manish-Sharma
    There is no particular advantage to adding the bracket before the number in the TOC since you have to run the find/change anyway.
    You can search for \t(\d+) and chage to [$1] and get the same thing without adding the bracket first.
    Also, there is no need to search the entire document. Set the scope of the search to Story and only the TOC will be affected (TOC must always be a self-contained story).
    Apr 13, 2012 4:34 AM   in reply to Peter Spier
    Great point, I believe I overthink sometime.
    Apr 13, 2012 5:58 AM   in reply to Manish-Sharma
    Don't we all.
    Apr 13, 2012 9:53 AM   in reply to wbset09
    Styles have never been intended to add content, and never will be (aside from things like underlines, paragraph rules and bullets and list nembers, all of which are considered "adornments" and cannot be selected).
    Apr 13, 2012 12:40 PM   in reply to Peter Spier
    Think in this way, Glyphs is not defined set , every font has its on Glyph sets
    and in that set every glyph has its own Unicode , which is Unique.....to include it in the GREP , we have to make the GREP font dependent ......and GREP will loose its basic functionality because it will not be able to serach the document just the fonts.
    Hence including Glyphs in GREP will screw up the things
