1
Extra bold text?
Apr 10, 2012 Apr 10, 2012
I create a WebHelp with RH 9. It is a new project which was created in RH 9.
The text contains words in bold (like this). Some short lines (style Normal like the text) are also bold. These lines are not headlines, but they should be highlighted in bold (see below).
To add bold I use the bold button of RH. When I generate the WebHelp and open it in Firefox (currently version 11), then words within a text and the short bold line look different ?! The single word appears extra bold and the line appears normal bold.
The genereated HTML looks like:
for a word: <span style="font-weight: bold;"><b>word in bold</b></span>
for the short line: <p style="font-weight: bold;">line in bold</p>
When I switch to the HTML view in RH it looks like:
for a word: <span style="font-weight: bold;">word in bold</span>
Why does the generation procedure handle bold things different? And why does it add the <b> tag for words within a longer text? I don't want to create a special style sheet for bold words when there is a button to make a word bold.
Can someone explain that?
Regards
DannyH
Classic
14.0K
Apr 11, 2012 Apr 11, 2012
I just did a quick test on RH9 and Robo inserts the span as wel as the for the span and the paragraph in my case. Is there a special routine you use for making bold paragraphs? I fiddled with several settings, but I could not get the result you describe.
Greet,
Willam
Apr 12, 2012 Apr 12, 2012
Hi Willam,
yes, RH9 inserts span. This is correct. Now generate a WebHelp and open this in a browser like Firefox 11. The single word within a text appears super bold and the bold paragraph appears normal bold. Right click into the text shown in the browser and display the HTML code. Now you see <span><b>word</b></span> (= super bold) and <span>paragraph</span> (normal bold).
Regards
DannyH
Apr 13, 2012 Apr 13, 2012
Mmmh, I tested on two different RoboHelp installations. On one installation, I don't get the result you describe. On the other installation I do get the HTML code you describe, but I don't see any difference in bold text in the output. I must be going nuts...
Could your CSS be interfering somehow by adding a 'font-weight: bolder;' to the <b> element? I will test some more to see what makes the difference.
Greet,
Willam
May 03, 2012 May 03, 2012
We are seeing the same issue in RH 9.0.1.232 on Windows 7.
The text <span style="font-weight: bold;">Text</span> becomes <span style="font-weight: bold;"><b>Text</b></span> when webhelp is generated.
Whether this appears as "super-bold" in a browser seems to vary depending on the user. When viewing the topic in Firefox 12, the bold text looked fine to me, but a colleague who viewed the same topic on her PC (also in FF12) saw the text as "super-bold."
I wonder if this means that it is something to do with some local browser settings or display settings on the PC used to view the topic?
Any idea why RH is inserting the <b> tags in generated files?
Cheers,
Dave
Sorry, to clarify, I didn't mean that each user's perception of the boldness of the text varied. The boldness of the text actually did look different on two separate PCs running FF12.
Dave
May 04, 2012 May 04, 2012
I've seen the code your describe and, as Willam, has stated, it will not affect appearance.
  1. What font are you using?
  2. Are the two PCs running at different screen resolutions?
It might help to see screenshots. Use the camera icon you will see when replying to insert the images.
@petergrainge
Hi Peter,
I think I figured this out. This seems to be a Firefox issue whereby the <b> tag in conjunction with some additional bold formatting on the text (via a style or span tag) is interpreted by Firefox as "bolder". We are using Arial 10pt for the style in the css, so Firefox looks for a font that is bolder than Arial Bold and renders the text as Arial Black.
This is apparently caused by Direct2D/DirectWrite hardware acceleration in Firefox. Disabling hardware acceleration resolved the issue for my collegue. You can do that from the Advanced tab in the Firefox Options dialog box. Interestingly, I have hardware acceleration enabled and I don't see the issue at all, so go figure!
Detailed discussion of the issue can be found at:
https://bugzilla.mozilla.org/show_bug.cgi?id=548975
https://bugzilla.mozilla.org/show_bug.cgi?id=550128
For reference, here is a screenshot of the topic in Firefox 12 from my colleague's laptop with hardware acceleration enabled.
Here is a screenshot of the topic in Firefox 12 with hardware acceleration turned off.
I'm not sure what the HTML/CSS specifications say about how the double bold formatting markup should be interpreted by browsers. Mozilla doesn't seem to consider this a bug.
However, I do wonder what the reasoning is behind RH inserting those <b> tags. If the HTML specs do say that <span style="font-weight: bold;"><b>Text</b> should be interpreted as bolder text, then RH's addition of the <b> tag is changing the markup to something that was not intended by the author.
Cheers,
Dave
May 05, 2012 May 05, 2012
Your images are the same size but note that the words at the end of the line starting "Pinnacle" are different. That suggests the issue is to do with the zoom level the two machines are set at. Check that out.
@petergrainge
May 08, 2012 May 08, 2012
this is interesting. I disabled hardware acceleration and the text appears as it should. All bold things have the same appearance - that is what I want.
Screenshot (disabled hardware acceleration):
Screenshot (enabled hardware acceleration):
Both have same zoom in Firefox 12, in version 11 it looked the same.
Telling the customers to disable hardware acceleration when using Firefox before reading the online help is not a good solution. The best would be that RH stops generating <span><b>...</b></span> things and this happens after I started the Web Help generation. I cannot influence this.
Regards
DannyH
I don't know if that is a bug but I can only suggest reporting it as such.
Can you identify a style difference between the first bold line and the second as that is where it is most obvious?
@petergrainge
Apart from reporting is as a bug, as a workaround, you can use a script or a search and replace to remove all the tags from your output. It’s more work for you, but you customers won’t have to do anything.
Greet,
Willam
There are the following differences for the example pictures above:
The source html file (before generation) contains:
<p style="font-weight: bold;">Aufbau der Online-Hilfe</p>
<?rh-list_start class="ListBullet" level="1" ?>
<p class="ListBullet" style="margin-left: 40px;"><span style="font-weight: bold;">Inhaltsverzeichnis</span><br />
Im linken Bereich erhalten Sie einen strukturierten Überblick über die einzelnen Hilfethemen.</p>
And the result html file after WebHelp generation contains:
<p class="ListBullet" style=" margin-left: 40px;"><span style="font-family:'Microsoft Sans Serif'" >•</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'><font size="1" style="font-size:6pt;">           </font></span><span style="font-weight: bold;"><b>Inhaltsverzeichnis</b></span><br />
Create a project with one topic that contains just the above content and uses the same CSS. Check your output from it does create the problem you describe.
See the Contact page on my site and send the project as instructed there. Do make sure you include a link to this thread and please do not email the project direct.
@petergrainge
May 10, 2012 May 10, 2012
I see similar differences in the source and output and have toggled the hardware acceleration before launching the help. I can see no diiference but a quick Google suggests it is only going to impact certain machines anyway.
Have you established the code you refer to is linked with the problem by editing an output topic to remove it?
Otherwise, my thinking is you are going to have to live with this.
@petergrainge
If those additional <b> tags in the output would not be there, everything would be ok. And those tags are definitely added by RH. I do nothing else than writing the content in RH and when finished I press the button for webhelp generation. I think, I write a bug report.
Of course I could delete all <b> tags from the output files  - hoping that there are no other <b> tags that are necessary somewhere. This workaround takes time: I have ca. 50 files, 6 languages and 3 variations for each language.
Which machines are mentioned by google? I'm working with Windows 7. Last year I was working with Windows XP and there I did not have this problem.
I am not arguing that you are doing anything with the code or denying that RoboHelp is adding the <b> tag. You are saying "If those additional <b> tags in the output would not be there, everything would be ok." My point was to edit those tags out of the output file to see if all is then OK. From what I am reading you are saying they are the cause but I am not clear whether that is theory on your part or that you have proved it.
Enter "Direct2D/DirectWrite hardware acceleration" into Google and see the first link. That suggests to me the setting will only affect machines with certain hardware.
@petergrainge
Ah, now I understand - this is sometimes difficult when communicating in a foreign language.
I have checked this. When I delete the <b> tags from the output files then everything looks great.
You are doing better than I would in whatever your first language is.
In Design View I created two paragraphs to start with and applied Bold to the first sentence and a single word, the to the whole second paragraph.
Where there are closing span tags, in the output you will get the extra <b> tags that are causing your problem. You will note there is no closing span tag in the second paragraph and no <b> tag gets written in the output.
<p><span style="font-weight: bold;">This is some sample text.</span> This
is some sample text. This is some sample text. This is some sample text.
This is some sample text. This is some sample text. This is some sample
text. This is some sample text. This is some sample text. This is some
sample text. This is some sample <span style="font-weight: bold;">text</span>.</p>
<p style="font-weight: bold;">This is some sample text. This is some sample
sample text. This is some sample text. This is some sample text. This
This is some sample text.</p>
Then I hit Enter and clicked the bold icon to return to normal weight and got this crazy HTML.
<p style="font-weight: bold;"><span style="font-weight: normal;">Sample
text added later.</span></p>
I have reported this as a bug.
Meantime try this. In Tools > Options there is an option Convert RoboHelp edited topics to HTML. Tick that and see if it makes a difference. It will apply to all projects.
Does that help?
@petergrainge
I remember that I have already seen this font-weight thing in my files. This is crazy.
Activating the Convert RoboHelp edited topics to HTML option does not change anything. Anyway, it was a good idea.
In that case the only option I see for now is Willam's script suggestion.
Sorry.
@petergrainge
I also think that this is the only option for the moment. Anyway, I add this to the bug list.
Thank you for your detailed analysis.
May 22, 2012 May 22, 2012
Another option might be to use a character style for bold text. That would probably be more work that using a script on the output files though.
Dave
May 29, 2012 May 29, 2012
I added this to my CSS and it fixed it right up:
b{
font-weight:bold;
Interesting, so Danny wasn't the only one with this problem.
Thanks for posting a solution Mike.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
