Rockydurangogeorgia
Patch tool, why mess with something that wasn't broken?
Apr 13, 2012 11:44 AM
I edit a large amount of product photography and I used to use the patch tool frequently to fix areas that needed cleaned up that had some sort of detail. Below you will find an image I was correcting and the result. I was not trying to get rid of the little nub, just replace it with one that looked better.
I tried to use the content replace tool as well and it not only changed the area I was trying to correct but the part I was taking from. It also left a weird shape around the part I replaced. See images below.
-original        -after replace tool
    Apr 13, 2012 12:32 PM   in reply to Rockydurangogeorgia
    You can still use the 'original' Patch Tool methods. Adobe simply added a Content-Aware option as well.
    Apr 13, 2012 12:34 PM   in reply to Rockydurangogeorgia
    The patch tool seems to work pretty much the same as always in Normal mode.
  • Noel Carboni
    Dec 23, 2006
    Apr 13, 2012 12:58 PM   in reply to R_Kelly
    I can confirm what the others have said.  I was able to do a very quick patch with the regular patch tool in Normal mode.
    The Content Aware mode is for something different entirely, when you want to give Photoshop more freedom to make believable looking stuff up from other parts of the image.
    -Noel
    Apr 13, 2012 1:10 PM   in reply to Rockydurangogeorgia
    I don't believe the algorithm changed for the Patch Tool. Can you post a comparison shot from CS5 vs CS6 using the Patch Tool as you normally would?
    Apr 13, 2012 1:38 PM   in reply to Rockydurangogeorgia
    Have you tried the "Destination" option on the Options Bar? You might be able to select a 'correct' nub, then drag it overtop of the 'incorrect' one.
  • Noel Carboni
    Dec 23, 2006
    Apr 13, 2012 1:44 PM   in reply to Rockydurangogeorgia
    Certainly doesn't look like it's working right in your second example, but that's not the result I got at all.
    I'm going to assume you know how basically to use the tool - that you'll need to drag to a similar part of another nub on the plastic.
    Funny thing was the second time I tried it I couldn't get as good a result as the first time - it seemed to want to make the nub too dark.  Only thing I had changed was the feathering of the Polygonal Lasso tool - I had reduced it.  Then I did the same in Ps CS5 and was not able to obtain a good result either.
    I did some more experimentation and I found that the best results are obtained with the Polygonal Lasso tool set to have some feathering - 2 or 3 pixels in this case.  Is it possible you're seeing a difference between how you have that tool set between PS CS5 and PS CS6?
    I kind of prefer the Healing Brush tool for this kind of work myself.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 13, 2012 2:00 PM   in reply to Rockydurangogeorgia
    It's possible it's broken specifically on your particular system, and maybe you need a video driver update to make it work properly.  This version uses the display pretty differently than its predecessor, which means it may be uncovering a bug in your driver.
    -Noel
  • Trevor.Dennis
    May 24, 2010
    Apr 13, 2012 3:04 PM   in reply to Noel Carboni
    I've found the new patch tool to one of the success stories in CS6, and find it works rather better than CA Move.  But as a regular user of the old patch tool, you will know that when correcting against an edge, you need to overlap both sides of that edge with the initial selection, and slide it along the edge to keep it aligned.   With the limited source pixels alongside your example, you would probably need two stabs at it.
