DTwo22
Blue ray Error -  "Device not ready", Code:"3", Notes -   Any ideas what this means?
Apr 11, 2012 4:57 PM
Tags: #cs5.5 #3 #blu-ray #build #error_code
After I clicked ok, then I saw where 23.98 of 24.98 GB was written.   Looked at bottom of BD and it was about 90% written to.   Any suggestions as what this may be or where I should be looking for the definitions for error codes?    I am lost on this one.  Don't even know where to start looking.
Thanks in advance for any suggestion you might have.
BTW, I am using CS5.5, most recent version.
Duane
Tempe, AZ
    Apr 11, 2012 5:19 PM   in reply to DTwo22
    What does it say after "Notes"?
    Did you try running "as administrator"?
    Do this before retrying:
    http://forums.adobe.com/message/2934387#2934387
    Also, try buildnig to image or folder to eliminate any burnder issues.
    Apr 11, 2012 7:00 PM   in reply to DTwo22
    >By Administrator, I assume that the user has Administrator privileges
    As well as the below, right click the Encore icon and select Run as Administrator, which is NOT the same thing as running the computer with the Administrator account, and which fixes several "odd" problems... To create a two layer DVD (or a BluRay?), you MUST have Encore set to use the Run as Administrator option
    Run as Administrator http://forums.adobe.com/thread/771202
    -Set to always "run as" via icon http://forums.adobe.com/thread/969395
    Odd Errors http://forums.adobe.com/thread/670174
    Media Offline http://forums.adobe.com/thread/790686?tstart=30
    Long File Names or odd characters cause problems
    Read http://forums.adobe.com/thread/588273
    And #4 http://forums.adobe.com/thread/666558
    And This Message Thread http://forums.adobe.com/thread/665641
    CS3 (maybe later?) Two Layer Problem http://kb2.adobe.com/cps/407/kb407236.html
    Encore "No Drive" Error http://forums.adobe.com/thread/569230
    Things and Software to AVOID when authoring/burning a DVD
    Start --> http://forums.adobe.com/thread/608660
    #2 has WHY Explained http://forums.adobe.com/thread/607390
    Plus http://forums.adobe.com/thread/562941
    Create an ISO (Encore) or folder on your hard drive (Encore or Premiere Elements) and then use the FREE http://www.imgburn.com/index.php?act=download to write files or folders or ISO to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
    Imgburn will read the ACTUAL disc brand from the disc, which is not always the same as the box label (Memorex is notorious for buying "anything" and putting it inside a Memorex box)
    When you write to disc with Imgburn, use the SLOWEST possible speed setting, so your burner has the best chance to create "good, well formed" laser burn holes... since no DVD player is required to read a burned disc, having a "good" one from a high quality blank will help
    Apr 11, 2012 7:38 PM   in reply to DTwo22
    Thanks Stan.   There was nothing after "Notes"   It appears that the message box was to small and it cut off everything after "notes.
    Here is another thread, in which Ramesh suggests that Code 3 points to faulty disks. If  you get any further info about the end of the message, let us know.
    The folder that I was referenced to does not exist in the Project tab.
    I assume you are referring to the "AuthorScriptHDMVSessions folder." I don't know how you could build a BD project without getting files in this folder. However, the folder is not created until the build, and a tmp folder exists until the build is complete, so I wonder if the final folder is not created when the build errors.
    Edit: saw your post just after I posted this.
    Apr 11, 2012 7:41 PM   in reply to DTwo22
    See John's note about imgburn and see if you can burn the folder to a disk.
    Drive/disk issues can be complicated.
    Apr 11, 2012 8:47 PM   in reply to DTwo22
    Part (most?) of the problems with Encore is that the "author core" is licensed from another company... and when the author core has a problem, the error message reporting is not always very good
    Being an Administrator when you use your computer is not the same as running as an administrator... I found that out the first time I tried to do a dual layer DVD... so use the link I sent to tell Encore that you always want to Run as Administrator
    I don't know if 50 characters is long enough to trigger that particular problem... my mind is still back in DOS 8 character days, so I always use short names, and have never had a problem
    I also NEVER go direct to disc out of Encore... I always have Encore create ISO/folder and then use Imgburn... an extra step, but Imgburn gives much greater control over the burn process... specifically, I always burn at the slowest possible speed
    Apr 12, 2012 6:03 AM   in reply to DTwo22
    John T Smith, me too I exported ISO and shorted name without free space.
    But I had a code 3 with a bad blu-ray disc (LG).
    I changed to a sony blu-ray disc and it worked.
    Bye
    Steph
    Apr 12, 2012 12:46 PM   in reply to DTwo22
    I use Imgburn for ALL disc writing... including files and folders for general data backup
    I have Imgburn's default set to 1x writing... and it then uses the slowest POSSIBLE speed of the media after it reads the parameters of the blank media
    I don't do BluRay, but I have never had a DVD fail
    Apr 12, 2012 8:48 PM   in reply to DTwo22
    I'm not at my BD burner machine, but help says Encore displays the drive's max speed and allows you to select a lower speed. I don't think the problem is that Encore is not allowing speed setting, but that something in this project/drive/disk etc allows only one speed.
    The Code 3 error message varies as to the content of the "Notes." All Code 3's are not AS_StorageErrors. We don't know whether your error message is truncated, or whether it is Code 3 with no Notes specified.
    Apr 13, 2012 9:07 AM   in reply to DTwo22
    Have you checked if you have the last firmware of your blu-ray player ?
    Apr 16, 2012 7:08 PM   in reply to DTwo22
    Sorry... I only do DVD, so have no idea what Imgburn setting to use for BluRay
    Apr 16, 2012 7:48 PM   in reply to John T Smith
    For many of the imgburn options there is a guide:
    http://forum.imgburn.com/index.php?showforum=4
    But I don't see one for BD.
    Set the mode for "Write files/folders to disk" (since you have a folder build).
    Drag in the folders so you see the BDMV and CERTFICATE folders in the imgburn window.
    If you simply burn at this point, ImgBurn will usually prompt you for any misfits.
    I am away from my production machine, and don't have a BD burner on this one.
    Jun 3, 2012 10:58 AM   in reply to DTwo22
    I also got Error Code 3 & Error Code 25 while using Encore CS5.5 for Mac while burning a 3:15 hour long wedding video on a 50 GB BD. Problem got solved when i renamed ppro time line to a short name with no spaces or other special characters. made a new project in encore, imported time line into it, just with name change transcoding time reduced too much and buring when normal.
