I'm trying to integrate unit testing with our build process and failing with the following error message.
BUILD FAILED
C:\Projects\project\client\FUTest\build.xml:88: Compilation failed: Warning: Source path entry, 'C:\Projects\project\client\FUTest\src\tests', is a subdirectory of source path entry, 'C:\Projects\project\client\FUTest\src'.
C:\Projects\project\client\FUTest\src\tests\SampleCase.as: Error: A file found in a source-path must have the same package structure '', as the definition's package, 'tests'.
C:\Projects\project\client\FUTest\src\tests\SampleSuite.as: Error: A file found in a source-path must have the same package structure '', as the definition's package, 'tests'.
I realize that my project structure does not match the sampleCIProject but I'm trying to fit this into an existing project that also does not match.
Here's the structure
FUTest/src/main/FlexUnitApplication.as
package main
public class FlexUnitApplication extends Sprite
public function FlexUnitApplication()
onCreationComplete();
private function onCreationComplete():void
var testRunner:FlexUnitTestRunnerUIAS=new FlexUnitTestRunnerUIAS();
testRunner.portNumber=8765;
this.addChild(testRunner);
testRunner.runWithFlexUnit4Runner(currentRunTestSuite(), "FUTest");
public function currentRunTestSuite():Array
var testsToRun:Array = new Array();
testsToRun.push(Request.methods(SampleCase,["simpleAdd"]));
return testsToRun;
FUTest/src/main/FlexUnitCompilerAppliaction.as
package main
import flash.display.Sprite;
import tests.SampleCase;
import tests.SampleSuite;
public class FlexUnitCompilerApplication extends Sprite
private var tests_SampleCase_obj:SampleCase;
private var tests_SampleSuite_obj:SampleSuite;
FUTest/src/test/SampleSuite.as
package tests
[Suite]
[RunWith("org.flexunit.runners.Suite")]
public class SampleSuite
public var t1:SampleCase;
FUTest/src/test/SampleCase.as
package tests
import flexunit.framework.Assert;
public class SampleCase
[Test(description="My First Actionscript Unit Test")]
public function simpleAdd():void
var x:int = 5 + 3;
Assert.assertEquals( 8, x );
FUTest/build.xml
<?xml version="1.0" ?>
<project name="flex unit test" default="info">
<property file="build.properties" />
<taskdef resource="flexTasks.tasks" classpath="${FLEX_SDK_DIR}/flexTasks.jar" />
<target name="info" description="flex unit test">
<tstamp />
<echo message="============================================"/>
<echo message="flex unit test"/>
</target>
<!-- GLOBAL SETTINGS -->
<property name="FLEX_HOME" value="${FLEX_SDK_DIR}/${FLEX_COMPILER_VERS}" />
<property name="EXT_LIBS" value="../ExternalLibraries" />
<taskdef resource="flexUnitTasks.tasks">
<classpath>
<fileset dir="${EXT_LIBS}">
<include name="flexUnitTasks*.jar" />
</fileset>
</classpath>
</taskdef>
<!-- PROJECT SETTINGS -->
<property name="FU_TEST" value="FUTest" />
<property name="SRC_FU_TEST" value="${basedir}/src" />
<property name="OUT_FU_TEST" value="${basedir}/bin/FUTest.swf" />
<property name="TEST_DIR" value="${basedir}/src/tests" />
<property name="OUTPUT_DIR" value="${basedir}/target" />
<property name="BIN_DIR" value="${OUTPUT_DIR}/bin" />
<property name="REPORT_DIR" value="${OUTPUT_DIR}/report" />
<property name="DIST_DIR" value="${OUTPUT_DIR}/dist" />
<target name="compile" description="Build the FU Test Project" depends="init">
<echo message="Compiling..." />
<exec executable="${FLEX_HOME}/${MXMLC}" failonerror="true">
<arg line="-compiler.include-libraries=${EXT_LIBS}/flexunit-4.1.0-8-as3_4.1.0.16076.swc" />
<arg line="-compiler.include-libraries=${EXT_LIBS}/hamcrest-as3-flex-1.1.3.swc" />
<arg line="-compiler.include-libraries=${EXT_LIBS}/flexunitextendedAS.swc" />
<arg line="-compiler.include-libraries=${EXT_LIBS}/FlexUnitTestRunner_rb.swc" />
<arg line="-compiler.incremental=true" />
<arg line="-debug=${debug}" />
<arg line="-default-background-color=${background.color}" />
<arg line="-default-frame-rate=${framerate}" />
<arg line="-default-size ${width} ${height}" />
<arg line="-source-path='${SRC_FU_TEST}'" />
<arg line="'${SRC_FU_TEST}/FUTest.as'" />
<arg line="-o=${OUT_FU_TEST}" />
<arg line="-use-network=true" />
<arg line="-static-link-runtime-shared-libraries=true" />
</exec>
</target>
<target name="init">
<!-- Create directories needed for the build process -->
<mkdir dir="${OUTPUT_DIR}" />
<mkdir dir="${BIN_DIR}" />
<mkdir dir="${REPORT_DIR}" />
<mkdir dir="${DIST_DIR}" />
</target>
<target name="test" depends="compile">
<echo message="Running Tests..." />
<!-- Execute FlexUnit tests and publish reports -->
<flexunit
workingDir="${BIN_DIR}"
toDir="${REPORT_DIR}"
haltonfailure="false"
verbose="true"
localTrusted="true">
<source dir="${SRC_FU_TEST}" />
<testSource dir="${TEST_DIR}">
<include name="**/*.as" />
</testSource>
<library dir="${EXT_LIBS}" />
</flexunit>
<!-- Generate readable JUnit-style reports -->
<junitreport todir="${REPORT_DIR}">
<fileset dir="${REPORT_DIR}">
<include name="TEST-*.xml" />
</fileset>
<report format="frames" todir="${REPORT_DIR}/html" />
</junitreport>
</target>
</project>
The initial complile seems works fine and produes bin/FUTest.swf. So why does the flexunit compile fail?
Any help most appreciated.
- mlindsay
