fotobuffflorida
Lightroom 4 and Topaz Labs
Apr 13, 2012 11:25 AM
I am able to see fusion express in the drop down under "Edit In", but not able to open. Does LR4 support Topaz Labs?
Jan Gemeinhardt
    Apr 13, 2012 12:16 PM   in reply to fotobuffflorida
    Yes, Topaz Labs plugins work fine with Lr. As I recall I had a problem earlier getting the two to recognize each other ... I downloaded the most current version of Fusion from the Topaz site and re-installed same and it worked fine after that.
    Apr 17, 2012 6:57 AM   in reply to fotobuffflorida
    Are you using LR 4.0 or LR 4.1 RC ? With LR 4.0, invoking external modules will fail most of the time. This applies to any plugin and to Photoshop itself.
    Apr 17, 2012 10:02 AM   in reply to fotobuffflorida
    fotobuffflorida ... I don't have any further advice ... and I also have no issue using Topaz Fusion to access the various plugins in Lr 4.0. Perhaps you should email the folks at Topaz and see if they know of any solutions. They are usually quite responsive ... though with the various problems with Lr4 (works great for some ... nearly not at all for others) ... not sure if they will know of any fixes ...
