Capturing video from a WDM Device
Apr 13, 2012 2:03 PM
Tags: #video #capture #premiere_elements_9 #wdm
I am trying to import video from our camera (a Sony DV camera from 1997!)
It worked with dv-firewire before, but now it isn't working, and we think there might be a problem with the dv connection on the camera...
We have WinTV 7, which captures and records television to the TV, and is connected with a "Hauppauge! USB-Live|2 Analogivideo digitizer"
So I unplugged the TV inputs from it, & plugged the camera in w/ component cables, and Premiere is able to recognize it, but it imports it with the bottom quarter of the file as a green bar. My project settings are standard definiion (4:3), so I don't understand why the imported video is being squished and has a green bar on the bottom of it.
Any ideas? I tried using the WinTV software and changing settings in there (in case that somehow controls the device's settings to...), I made sure that too is set to 4:3...I tried right-clicking in the capture window and played with the capture settings & device control....nothing!
I've attached a picture.....where you can clearly see the green line I'm referring to.
Help would be appreciated!
    Apr 13, 2012 2:39 PM   in reply to LNPato
    • First try another FireWire cable.
    • When using your TV card is the green bar an addition to the video or obscuring a part of it?
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Apr 13, 2012 2:58 PM   in reply to LNPato
    each plugging into a "Dynex FireWire 800 ExpressCard Adapter"
    Does that adapter also have an IEEE-1394a (FireWire400) connector on it? PrE will not be able to Captrue over IEEE-1394b.
    If so, does that connector work with another IEEE-1394a device?
    Can you Capture through your Hauppauge card via Windows Movie Maker, on some other such software?
    Good luck,
    Hunt
    Apr 13, 2012 5:06 PM   in reply to LNPato
