DebG_
Using a file from INDD 5.5 in INDD 5
Apr 13, 2012 3:48 PM
Tags: #cs5 #indesign_cs5
There were no results for I have received a file from a client who uses 5.5 - I use 5 - she saved the file in idml format which she says should make it so I can open it. I have used Adobe Application Manager and made sure I am completely updated. I get a note saying the the file 'uses one or more plug-ins which are not currently available on your system' - and another one saying to upgrade my plug-ins which I believe I have. Does anyone have suggestions - is there a way for me to access this file.
    Apr 13, 2012 3:57 PM   in reply to DebG_
    This typically because the person did nothing but change the file extension. IDML must be exported from InDesign.
    Bob
    Apr 13, 2012 4:07 PM   in reply to DebG_
    I suppose it's remotely possible that you are using InDesign CS3 (InDesign 5.0) and your client is using InDesign CS5.5 (InDesign 7.5). That confusion in version-naming conventions would lead to the same "wong-plugin" problems. But Bob is probably right - I am astounded to see how frequently it happens that someone thinks that changing a file extension actually changes the contents of the file.
    Apr 13, 2012 4:09 PM   in reply to Joel Cherney
    CS3 would completely choke on an IDML file, I would think.
    Bob
    Apr 13, 2012 4:18 PM   in reply to Bob Levine
    I apparently have already used up all of my available brainpower for the day. You're exactly right, Bob. Please do ignore my message, Deb, I was 100% incorrect.
